Ive done but its been a while. I know that I removed the whole jug from the car. I think I just used a deepwell socket and extension. Being plastic, I didnt try and get it very tight.
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Found out you need 22mm deep bowl socket
Also found out pump is fine, filter was bloched with 20 years of coagulated washer fluif. Probably could have just used a bottle brush and clean water to clean it on the car
