1994 emergency brake
When you pull it up, do you feel spring tension?
As you lower the handle, do you continue to feel spring tension?
When you depress the button on the end, do you feel some light spring tension?
Basically, the unit is a ratchet with a locking lever, which the button, when depressed, unlocks. Otherwise, the locking lever always engaged, However, there is a pilot hole in the mechanism, into which a pin (nail) can be inserted to hold the locking lever in a 'disengaged' position -- perhaps the pin is still inserted from prior maintenance of the brakes?
There are two screws which hold the plastic cover on the mechanism (may require removing the lower seat bolster to gain access and moving the seat all the way rearward).
Please note, the arm is designed to swing down out of the way, while still retaining the brake's engagement -- to disengage the brake, it requires lifting the handle until you feel spring tension and then depressing the button to release the locking latch, then while holding in the button, lowering the handle all the way, to fully disengage the brake.
[/IMG]
I got it working !!! That was all I had left to get an inspection sticker ! THANK YOU CORVETTE FORUM !!!!!
