Anyone using :Corvette Throttle Performance Switch
Old May 5, 2009 | 05:00 PM
rad928music's Avatar
rad928music
Default Anyone using :Corvette Throttle Performance Switch
Its a plug in device between the Tps.
They claim it will give you better throttle response.
Old May 5, 2009 | 05:26 PM
M.J.L.'s Avatar
M.J.L.
St. Jude Donor '10-'11
It's crap. They wear out within a year. They do give better SOTP feel but only because it fools the comptuer. It gives no real power back. Ask me how I know. Save it and put it towards something else. A aftermarket tune would give you better SOTP and hp than that piece of garbage and isn't much more. I threw mine out along with the air foil, K&N filter, and all that other snake oil they tricked me into buying years ago.
Old May 5, 2009 | 05:41 PM
StealthLT4's Avatar
StealthLT4
All it does is give more throttle to the engine than you give to the pedal. So you give 60% on the pedal, and it gives the engine 90%. No gians at WOT, and actually takes away throttle modulation from you, since you now have a harder time specifying specific throttle angle.
Old May 5, 2009 | 05:42 PM
floridamale's Avatar
floridamale
Old May 5, 2009 | 06:08 PM
vader86's Avatar
vader86
junk
Old May 5, 2009 | 06:22 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
It is related to the airfoil and has the same DNA.
Krap, Crap, Qrap
Old May 5, 2009 | 07:45 PM
TA's Avatar
TA
Save yourself a few bucks and just step on the go peddle a little harder when you want to go faster
Old May 5, 2009 | 08:00 PM
tankman's Avatar
tankman
I assume this is the plug in device that was on my '87 when I purchased it.I unplugged it and the 'vette ran awful,so I plugged it back in.It's still there and the 'vette gets me from point A to point B.
tankman
Old May 5, 2009 | 08:42 PM
383vett's Avatar
383vett
How does this possibly give you "more throttle to the engine"? With mechanical (cable) linkage, 60% throttle is 60% throttle.
Old May 5, 2009 | 09:24 PM
M.J.L.'s Avatar
M.J.L.
I think he means it fools the computer into thinking your giving itm ore throttle than you really are....I still stand by what I said. Junk. Thank the Chinese for that one.
Old May 5, 2009 | 10:23 PM
383vett's Avatar
383vett
That could only happen with a fly by wire system which started in the 1997 c5 vettes.
Old May 6, 2009 | 09:59 AM
M.J.L.'s Avatar
M.J.L.
I wonder if i can fool my cars computer into thinking it has a 383 in it.
Old May 6, 2009 | 10:04 AM
Demonic85's Avatar
Demonic85
By "fooling" the ECM into thinking theres more throttle its not actually opening the throttle body blades any more than what your foot is telling it to. The ECM just advances fuel/air flow readings to the increased level, not the throttle itself.
Old May 6, 2009 | 10:14 AM
rickneworleansla's Avatar
rickneworleansla
Thats what I thought also. If this is the same one I saw they claim it can overcome a stretched throttle cable which had me thinking since I believe mine is worn. If all it is doing is fooling the computer into thinking it's at a higher throttle position that can't be good since the blades are still not fully open. I passed on it as I continue to search for a new cable.
Old May 6, 2009 | 10:19 AM
floridamale
Electronic Snake Oil
Old May 6, 2009 | 10:58 AM
MBDiagMan's Avatar
MBDiagMan
As beat to death here, the gadget simply sends a modified Throttle Position Sensor signal to the ECM. I expect that you would indeed feel a difference, but it would offer no real performance gain as others pointed out.
You can incrementally change the throttle response by adjusting the TPS. Use a voltmeter and make small changes, like about .02 Volts at a time. After a change, drive it to see if you like it. Once you find a setting that feels good to you, write it down where you can find it. Then if you ever have to do any repairs that require TPS readjustment, you will know what to set it to.
Don't expect any Earth shattering difference by doing this. The effect is minimal, but it will probably be as much as you would get with the gadget. Also, just like the gadget, this will not effect WOT performance unless the Voltage at WOT is appreciably changed.
BTW, the comment about such changes only pertain to a drive by wire system is not exactly correct. Although you do have a mechanical linkage to the throttle plate, the TPS is a similar signal since it is, in effect, electrically measuring the position of the gas pedal.
To Anyone using :Corvette Throttle Performance Switch
