Differences in LT1/LT4 short block
Old May 7, 2009 | 07:57 PM
pushrod-v8's Avatar
pushrod-v8
Originally Posted by cheetah
Why?
yes, its "technically" incorrect, but aside from the reverse flow cooling system and opti spark, its basically the same block. Of course there are other minor differences, but it is basically the same block.
The LS1 engine is totally different block from top to bottom. Completely new design, completely different all around from a to z. Big difference.
*edit* and this is excluding the LT5 from the '90 to '95 ZR1 Corvette.
Old May 7, 2009 | 08:28 PM
BlackHarleyMan's Avatar
BlackHarleyMan
Originally Posted by pushrod-v8
I always refer to the SBC up until the ls1 came out as a 1st gen small block.
It's still the Gen-II Block, no matter how you call it, if it walks like a duck and quacks like a duck, then 9 times out of 10......It's a Duck!
Noland
P.S. The LS1 motor is a Gen-III
Old May 7, 2009 | 08:35 PM
pushrod-v8's Avatar
pushrod-v8
Noland
quack quack....
it's a duck!
Old May 7, 2009 | 08:58 PM
BlackHarleyMan
quack quack....
it's a duck!
Yes Sir, that there is a Good Ole American Duck!
Old May 8, 2009 | 08:57 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
This guys selling his stock crank
http://forums.corvetteforum.com/c4-f...nterested.html
Old May 8, 2009 | 12:35 PM
96lt4c4's Avatar
96lt4c4
I have a stock LT4 crank with 50K miles on it lying in the top of my garage if you are interested. Its in good shape. The only reason i tore the motor down was to build a 383. It was suppose to just be a cam swap.....
Old May 8, 2009 | 01:07 PM
pianoguy's Avatar
pianoguy
Thanks for the leads on a crank - I'll keep that in mind!
Old May 8, 2009 | 11:27 PM
tpi 421 vette's Avatar
tpi 421 vette
Personally, if your going to tear it apart, why not do a 383. You can build one as cheap or cheaper these days than a 350. Especially if you have to by pistons. And the torque improvement with a 383 is huge.
