coolant question
Old Feb 4, 2002 | 02:11 PM
flubuyu2's Avatar
flubuyu2
Default coolant question
here it is guys;I have a 93 and my friend told me yesterday that when i changed over to the"pink"coolant it will erode the internals of the lt1??When I did this i also changed the freeze plugs to ensure i got all the green out(don't mix will turn into mud!!!)then i also put the GM sealer in.I used the GM certified havoline stuff .I went through old postings and am conflicted!someone please break it down for me??!!am i killing my engine??
Old Feb 4, 2002 | 02:19 PM
Thud's Avatar
Thud
Default Re: coolant question (flubuyu2)
I haven't heard of the mixture actually turning into mud.
However, it definitely is best to flush the system out completely before changing coolant types. A little bit of the green stuff effectively negates the advantages of using the pink stuff.
The "pink" stuff (Dex-Cool) will still work if there's a little bit of green stuff left, but the service interval is reduced to only 2 years, instead of much longer-- 100,000 miles or whatever that the pure pink stuff is supposed to give you.
[Modified by Thud, 1:19 PM 2/4/2002]
Old Feb 4, 2002 | 02:53 PM
flubuyu2's Avatar
flubuyu2
Default Re: coolant question (Thud)
I wasn't sure of mixing got the mud thing from a previous post! got most all I believe though(still pink!)My real concern is the "erosion "that my friend was talking about,is this for real??
Old Feb 4, 2002 | 02:57 PM
Red Dwarf's Avatar
Red Dwarf
Sent you some info that shud help. :cool:
Old Feb 4, 2002 | 03:10 PM
flubuyu2's Avatar
flubuyu2
Default Re: coolant question (lou sylvestri)
Thanx,very informative,it seems the verdict is keep as close to 50/50 mixture as possible to keep the correct level of corrsive inhibitors also at the correct level!The only problem with a little mixing of the coolants seems to be shorter life span.again good info thank you
Old Feb 5, 2002 | 05:29 AM
Yello95's Avatar
Yello95
St. Jude Donor '11
...new radiator...and plain ole Prestone...50/50...works for me... :D
To coolant question
