Intake manifold help needed
Old May 8, 2009 | 04:02 PM
idprints's Avatar
idprints
Default Intake manifold help needed
What is the torque and sequence for my 1994 intake manifold?
I have to change gasket first timer.
Old May 8, 2009 | 04:56 PM
jimg's'93's Avatar
jimg's'93
For a 1993:
1) Apply a 5mm (3/16") bead of RTV sealer to the front and rear of the engine block. Extend the bead 13mm (1/2") up each cylinder head assy. to seal and retain the gaskets.
2) Install gaskets and intake.
3) bolts/studs as follows:
First pass = 71 in. lbs.
Sequence is:
12 11 4 1 5 6
<---Front
10 9 3 2 7 8
Second pass = 35 ft. lbs., same sequence.
Hope that helps!
Old May 9, 2009 | 10:37 AM
idprints's Avatar
idprints
Thanks for help, just what i needed!
To Intake manifold help needed
