hard start when hot
Old May 9, 2009 | 07:26 PM
chips88's Avatar
chips88
Default hard start when hot
changed cold start valve, same problem, pump gas pedal 4 to 5 times, motor starts.
Old May 10, 2009 | 06:17 PM
chips88's Avatar
chips88
should i change fuel prssure gauge.
Old May 10, 2009 | 06:28 PM
jfb's Avatar
jfb
Pumping the gas pedal during cranking can flood the engine. Keep your foot off the accelerator when starting. Measure the fuel pressure, engine hot, and see if the pressure holds up for a long time after the ign is off. If it falls rapidly, you have a leaky injector/s, or a bad check valve in the fuel pressure regulator. Also, pull a plug wire and bring a grounded wire close to the plug wire while someone cranks the engine. You should see at least a 1/2" snappy spark. If you have a weak spark, you likely have a spark control module at the end of its life.
Old May 10, 2009 | 07:09 PM
floridamale's Avatar
floridamale
It seems that with today’s fuels which cause injector failure most hard start when hot conditions are do to the injectors going bad, you need to check the resistance with a ohm meter both hot & cold . Next time don’t pump the pedal just hold it steady ¾ open, start car see if that helps I believe that will help clear a flooded condition. I’m sure others will give advice on this also.
Old May 10, 2009 | 07:22 PM
jfb's Avatar
jfb
Holding the accelerator all the way down shuts off the injectors so that you can clear the engine during cranking. DO NOT hold the accelerator at 3/4 throttle!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Old May 10, 2009 | 07:47 PM
floridamale
I didn't remember if was all or part open I have no starting issues with my car thanks. But the OP should not be pumping it at all
Old May 11, 2009 | 12:55 AM
williammackean's Avatar
williammackean
St. Jude Donor '07
I had this, too. It went away when i replaced the MAF connector and added another ground to that circuit AND another ground from the battery's frame connection directly to the engine block. And I mean this makes my beast start like she's ice cold overnite!
I was fixing an intermittent MAF code. Might help you?
To hard start when hot
