CTS problem from hell, please help!
If you disconnect the CTS connector and short the Yellow wire to the Black wire, start the engine, the ECM should think the engine temperature is over 266F and the fan should turn on.
If this is an 89 Vette, another way to verify the fan works is short pin A to pin B on the diag. connector above the drivers knee and turn the ignition On. The primary fan should run.
If you had some scanning software like Diacom you could display the CTS, MAT and TPS sensor readings.
You can also check the ECM by disconnecting the Fan Switch on the high side a/c line. If the fan doesn't come on, there's a relay, wiring or ECM problem.
The ECM uses the CTS for fuel delivery - its' not just for non a/c fan control so verifying/getting it to work correctly is important.
I'd still check for a 5 volt reference at the ECM Pin and Connector. If there wasn't a sensor ground, the voltage wouldn't drop on your Meter - it's either there or it isn't - so high resistance on the reference circuit remains a possibility. Did you splice in a new connector? Have you punctured any wires to obtain voltages? Either could create resistance.
There should be a chart available to reference temperature to resistance in the sensor. Idk if it would be worthwhile to test it, since you say you've tried more than one.
Is it possible you're getting the wrong part?
You had the intake off so presumably the system was drained. Is it possible that the flow of coolant isn't getting to the sensor? Airbound?
first, what temp do you expect the fans to come on?
my car: E86, auto. mostly stock, 5 year old GM radiator
air conditioning off.........fan on at 225, off at 215.
air conditioning on.........fan on at 217, off at 212.
on the freeway, 65 mph, outside air temp at 100 F indicated, coolant temp is 185,
on the city streets, outside air at 100 F,steady 45 mph with occasional light, coolant temp is 198-210.
stop and go, heavy traffic, outside air temp at 100 F indicated, coolant temp is 217-225.
outside air temp at 115 F indicated, coolant temp on fwy is 198, at 45 mph, 205, and stop and go it's 212-224.
usually the temp indicated is 100 degrees higher than outside air temp.
What temps do you expect to see?
part 2
If you jump the cooling fan relay coil + from the alternator with a wire with alligator clips and a paper clip, the fans should start if the coil negative is grounded, and the relay is good.....Next, if the fans don't start, check the relay connector for corrosion in the plug that plugs into the fan relay.
If all is good, then ohm the wires from the fan relay plug back to the ecm, and to the ground. Then check the power wire from the fusible link to the battery. Then the relay to the fans.
The relay should get 12V all the time on one of the relay big contacts, and the smaller wires run the coil that energizes the relay. If no 12V, then the fusible link is suspect, if no ground, the ground wire from the ECM is suspect.
If all is good, try borrowing an ECM from somebody. See if that is the problem.
Check codes, Sometimes the fan problem can be in the prom.
