96 A/C Problem
Old May 12, 2009 | 11:35 PM
Yellow96coupe's Avatar
Yellow96coupe
Default 96 A/C Problem
This is my first vette and my first post. I have looked through all the other threads and have not found anything with my exact problem. I bought a 96 coupe and the A/C only blows on defrost and will not move to any other vents. i have seen multiple posts about where it will blow on defrost for 5 mins. then move to the regualar vents, Mine does not do this just stays on defrost all the time. It has the automatic climate control and non of the buttons seam to work. I can't adjust the temp. or the fan speed either. The only button that seams to work is the rear defrost button. Once i push that button it stays on for a couple of seconds then turns off.
Any help would be appreciated.
Old May 13, 2009 | 12:13 AM
grinditout's Avatar
grinditout
The controller might be out, are you getting conditioned air at all?
Is the compressor cycling and sweating?
Old May 13, 2009 | 12:21 AM
Yellow96coupe
the air that comes out on the dash is extremly cold. im not sure if it is cycling or not.
Old May 13, 2009 | 12:22 AM
Yellow96coupe
correction the air that is coming out of the defroster vents is very cold
Old May 13, 2009 | 01:36 AM
grinditout's Avatar
grinditout
It sounds like the air exchange is working, so it is a door problem, pull the controller, do a search it has some engineering flaws.
Old May 13, 2009 | 07:12 AM
pcolt94's Avatar
pcolt94
On the right side of the engine underneath the plastic valve cover about ½ way down there is a small black looking valve type unit with 3 hoses to it. That unit routes the vacuum to you’re A/C vent control (and cruse). No vacuum, no control and it blows to the defroster. Check it for cracks or just plane falling apart. This is a common problem and most likely yours.
It’s a $5 part and can be bought from GM and other auto part supplies. Don’t have the part number or picture of it. It is easy to replace.
Old May 13, 2009 | 07:26 AM
mikes96's Avatar
mikes96
Yes pcolt94 has it right, my 96 had the same issues I checked that check valve and it was shot, replaced it with one from Autoznone 3.99 and my HVAC now works great.
Old May 13, 2009 | 07:40 AM
runner140*'s Avatar
runner140*
A place to start is the check valve. Its under the fuel rail cover on the right side of the engine. Its a cheap part called a check valve.....
buy a "universal check valve". If that doesn't do it, its your controller.
Its located above the gas pedal on the fire wall. It has soft plastic nipples that colapse with age and need to be trimmed back. Its a difficult job.....more that a couple hours but there is much written on the subject. Do a search using the words "A/C controller problem 1996". Good luck.
Old May 13, 2009 | 07:46 AM
eherbst's Avatar
eherbst
if its not the check valve pull the ac controller out. Its under the driver side dash with the vacuum plug going to it. The nipples on the back of the controller get soft and collapse and will not allow vacuum. Just trim down the soft tips with a razor blade and put it back together and it will work great.
Old May 13, 2009 | 10:22 AM
Yellow96coupe
thank you to all that have responded. this helps me out
Old May 13, 2009 | 11:38 AM
LannyL81's Avatar
LannyL81
Default Temp Door
To check the temp door operation; push the AUTO button and with cold air coming out of the defrost vent, change the temp to 90 and check to see if the air out hte defrost vent becomes hot. If so, then the temp door is working just fine.
Most likely problem is either the vacuum check valve is shot (the one under the right fuel rail) or its the temp controller vacuum connector pinching-off. There are couple of fixes for this. All require the removal of the controller...which is a royal PITA to do, especially the first time.
Do a search for hints or PM me and I will be glad to detail it out for you.
Easy fix...just a pain to do.
LannyL81
Old May 13, 2009 | 12:45 PM
Gary96's Avatar
Gary96
My 96 had the same problem when I bought it. I took it to the dealer and they didn't replace any parts so I think it was the soft plastic nipples on the controller above the gas pedal. There is a nice write-up with pictures on how to fix this problem somewhere on this board.
Old May 13, 2009 | 12:57 PM
Yellow96coupe
im hoping it is that small fix. Right now i cant even change the temp. to see if it will blow hot air out. You all great and i appreciate this thank you
Old May 13, 2009 | 03:21 PM
larryfs's Avatar
larryfs
It's the programmer box under the dash board, above the gas pedal.
and you also need the controller under the radio.
you have 2 problems.
and I have all the parts...........
Old May 13, 2009 | 03:29 PM
grinditout's Avatar
grinditout
Yeah, if you can not adjust the temp then the climate controller is out.
Old May 13, 2009 | 04:41 PM
pcolt94's Avatar
pcolt94
Here is the link for the write up and pictures for the controler nipple fix.
Hopefully this does not have to be done.
http://forums.corvetteforum.com/c4-t...l-problem.html
To 96 A/C Problem
