Idle Problem 96 LT1
Old May 13, 2009 | 04:05 PM
Tcioffipe's Avatar
Tcioffipe
1st Gear
Default Idle Problem 96 LT1
I have a 96 LT1 with an idle problem. I just had the front seals replaced, water pump changed, radiator replaced, rotor cap and wires replaced. When the car is first started it idles smoothly. After a few minutes the idle starts to surge for a few seconds and returns to normal. This is akin to the AC cycling on and off. We turned the AC off and this did not stop the problem. This only started after I had the car serviced. We checked for vacuum leaks, cracked hoses etc. We spayed carb cleaner to try to find the problem but have been unsuccessful in locating the problem. The car has 51,000k and runs great.
Any suggestions???
Thank You
Anthony
Old May 14, 2009 | 07:34 AM
Weav's Vet's Avatar
Weav's Vet
No answer but if you find out what is causing it let me know.
I have the same problem on my '96. I had the very same repairs done you did and it hasn't been right since. I am starting to wonder if the stock opti doesn't like the replacement cap and rotors that are out there. I have chased this thing for months, replaced every part I can find that may be causing it and no luck. It's still there in closed loop.
Old May 14, 2009 | 07:57 AM
Epimax's Avatar
Epimax
My first guess would be the IAC valve, or maybe the EGR valve?
Old May 14, 2009 | 04:36 PM
MY PROZAC's Avatar
MY PROZAC
I had the same problem with my 93 a couple of years ago. I replaced the EGR valve and it seemed to correct the rough idle.
Its an easy and cheap place to start. I picked one up for $28 from GM.
Old May 15, 2009 | 08:29 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Did you physically remove the entire TB or just spray TB cleaner in it? It's best to remove the entire assembly for thorough cleaning.
Get a large, plastic Tupperware bowl, a can of TB cleaner, some shop towels, and old toothbrush, and a can of idle air control (IAC) cleaner. Then, remove the TB assembly, spray it down real good with the TB cleaner, and go to town with the shop towels and toothbrush.
Remove the IAC motor pintle and clean any traces of carbon from the spring. That's likely your problem right there, carbon build-up. Be sure and replace the IAC gasket with a new one or cut one from gasket paper. Make sure you wet the gasket with a dab of motor oil before bolting it back to the TB housing to ensure a tight, leak-free seal.
I clean my TB in this manner once a year. It really mellows the base idle, improves throttle response and fuel economy, too.
Old May 15, 2009 | 09:19 AM
Weav's Vet's Avatar
Weav's Vet
All very good advice but I don't believe the '96s have a gsaket. They have an O ring.
If they do I'm missing mine and one didn't come with the new IAC I bought a while back. Maybe I need to make one for it. I have the same type idle issue.
Old May 15, 2009 | 09:49 AM
runner140*'s Avatar
runner140*
Any suggestions???
Thank You
Anthony
Think about cleaning the IAC or replacing it. Its a cheap part and easy to install.
Follow the sequence in your FSM for resetting the IAC.
Old May 15, 2009 | 01:44 PM
JAKE's Avatar
JAKE
Did you check the plastic hose connectors?
There's a plastic vacuum hose fitting on the passenger side of the intake, under the CORVETTE cover that could be cracked and leaking. On my 96, the hose was good but as soon as touched the little hose barb it fell apart.
I'm assuming the Opti Vent hoses (2) were reconnected, right?
Jake
West Point ROCKS!
To Idle Problem 96 LT1
