how much oil should a new engine burn?
Old May 13, 2009 | 08:04 PM
slickfx3's Avatar
slickfx3
Default how much oil should a new engine burn?
My used around half a quart for the first 400 miles
Old May 13, 2009 | 08:07 PM
engle1147's Avatar
engle1147
Have you checked for leaks?
Old May 13, 2009 | 09:02 PM
slickfx3's Avatar
slickfx3
no leaks, i would see it on the ground, no?
the engine is shot now right?
Old May 13, 2009 | 09:05 PM
ultraviolet70's Avatar
ultraviolet70
Low tension rings?
Broken in properly?
What RPMs are you turning?
What are some of the specifics on the build, who built it, was it done properly?
What oil are you using?
Answers to these questions will make it easier give accurate answers to your questions?
Old May 13, 2009 | 09:16 PM
slickfx3's Avatar
slickfx3
Originally Posted by ultraviolet70
Low tension rings?
Broken in properly?
I hope I broke it in properly
Mahle power pak rings, came with the pistons
QMP racing motors, yes I believe it was done properly
I spin it to 5,000 or 5,500 on occasion, I didn't baby it for th last 300 miles, I did change the oil once at 100 miles, from 5w30 dino to 10w30 autozone dino.
Is this normal usage?
Old May 13, 2009 | 09:21 PM
engle1147's Avatar
engle1147
1/2 quart low could be from the oil being transfered from the pan to the oil filter and passage ways. Was the "new" engine primed before you checked the fluid level? Point being that it would look to be low now if the oil filter was empty when you checked the level just after the fill then.
Old May 13, 2009 | 09:27 PM
slickfx3's Avatar
slickfx3
was primed, it went 1/4 qt low, and the next day i had to put in 1/4 qt, but the car is not smoking....
Old May 13, 2009 | 09:52 PM
ultraviolet70
I wouldn't condemn it yet. Get some more miles on it, keep an eye on your oil which I know you're doing and keep a detailed log of mileage and usage.
What are the specifics on your heads, are they new/rebuilt? If rebuilt what about the guides, knurled?
How does it run?
Pull your plugs and take a look.
Do a leakdown test.
Try these things/watch these things and let us know your results.
As far as being shot I'd definitely do some more diagnosis and give it some more time before I'd say that.
Old May 13, 2009 | 09:56 PM
slickfx3's Avatar
slickfx3
How does it run?
Do a leakdown test.
New AFR 195 eliminator heads
plug looked good burning right
no leakdown test
Does the usage seem severe?
Old May 13, 2009 | 10:01 PM
Pete K's Avatar
Pete K
no leakdown test
No
A quart every 800 miles sounds severe, but it is not.
Every chevy motor I have ever built burns oil when used hard.
By coincidence, the motors that used the most, ran the best.
My 10 secon nitrous motor uses a quart of oil every time I took it to the dragstrip, and 1 qt every 700 miles when driven normally.
ultraviolet70
I've heard of higher oil consumption, but 1/2qt every 400mi translates into almost 4qt every 3k mi which is definitely more than I'd want.
Also forgot to ask how is your PCV/breather setup configured now?
Old May 13, 2009 | 10:10 PM
slickfx3's Avatar
slickfx3
stock pcv configuration , I noticed in the past, new oil was more susceptable to loss, whereas oil that's been in the case over 1000 miles tend not to deplete.
did anyone notice this in their rides, I do and for years have experienced this
Old May 13, 2009 | 10:13 PM
slickfx3's Avatar
slickfx3
Originally Posted by Pete K
No
when you say chevy is that your only engine building reference?
I do run the **** out of it, and it's new
where does the oil go?
when you say ran the best, you mean the hardest hitting? longest lasting? best gas mileage?
Old May 13, 2009 | 10:38 PM
Pete K's Avatar
Pete K
All of the above.
Performance motors use oil. New performance motors often use alot of oil until broken in. My experience is that 3,000 miles or so is needed for complete break in.
And my personal experiences are with more than chevy's.
Chevy small blocks do seem to be "oil thirsty"
Old May 13, 2009 | 11:12 PM
JAKE's Avatar
JAKE
There are several variables involved here which could account for it: Ring thinkness;
Ring end gaps,
Type of second ring,
Type of oil ring set,
Piston to wall clearance,
Proper positioning of ring end gaps on pistons,
Cylinder wall finish,
Ring fit in piston,
Proper ring installation,
Valve stem sealing,
and probably others I can't think of off the top of my head.
Of course, if you didn't build it yourself you won't know many of those and have to trust in the precision on the builder.
Jake
West Point ROCKS!
Old Jan 24, 2020 | 05:19 PM
Scream And Fly's Avatar
Scream And Fly
This motorman guy and his ridiculous break-in analysis seems to live on to cult status. Unreal.
Old Jan 24, 2020 | 08:37 PM
Hot Rod Roy's Avatar
Hot Rod Roy
Why did you bring him back from the grave? He's been gone a loooong time! Unreal!
To how much oil should a new engine burn?
