85 Vette starter
Old May 13, 2009 | 11:41 PM
joe wilson's Avatar
joe wilson
Default 85 Vette starter
Hi, I was wondering how difficult it is to install a starter on an 85 Corvette. I bought a mini-starter and was wondering if I should try this or have it done.
Old May 14, 2009 | 12:46 AM
tdf's Avatar
tdf
St. Jude Donor '11
Default Just Did a Starter R&R on an 86 4+3
Get front and rear up on jack stands.
Remove the entire exhaust system and drag it out of your way in one piece (3 bolts each side to get the exhaust loose from the headers, 2 bolts in a hanger infront of the cat, 1 in a hanger on the Y-pipe and the 2 in the rear hanging the mufflers). Reason: there just isn't room otherwise). While doing this be lucky and don't break any fasteners. I was lucky, but I don't drive mine in the wet unless I get caught out in a shower and none were frozen.
Then it's easy to get the 2 bolts out of the starter and rotate the starter to a position to get the 2 wires loose.
Also there is a support braket you have to undo at the front of the starter.
If it sounds intimidating, it really wasn't that bad!
Mark85Vett's Avatar
Mark85Vett
Its 2 connections and 2 bolts...just get the car up high enough and you'll be fine! Just make sure you disconnect the battery first!!
Old May 14, 2009 | 07:51 PM
joe wilson's Avatar
joe wilson
Did you mean 2 exhaust connections? I hate working with rusty bolts because I'm sure I'll break at least one off! I assume the 2 bolts are the starter bolts on the bottom. Probably a good idea to check the teeth on the flex plate too?
Old May 14, 2009 | 08:54 PM
LD85's Avatar
LD85
Do it, the mini is a good upgrade for sure
Old May 14, 2009 | 09:01 PM
Targa86's Avatar
Targa86
cant get any easier than that...good luck!
Old May 14, 2009 | 10:41 PM
mikey whipreck's Avatar
mikey whipreck
You don't need to move the exhaust on an '85, just move the tranny and fuel lines out of the way a bit
Old May 14, 2009 | 11:01 PM
eguyett1985's Avatar
eguyett1985
Yep, if you don't have headers then it's pretty darn easy. You can move the trans cooler hard lines a little by hand and it will come right out.
Old May 14, 2009 | 11:17 PM
Muffin's Avatar
Muffin
What he said. You did the right thing with the mini starter. Solves a multitude of problems at one time.
After rereading mikey's post, not sure you have to worry about the fuel lines. Been a while since I pulled an old style starter.
Old May 14, 2009 | 11:46 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
Changing the starter was probably the easiest thing I've ever done on the Corvette. Didn't take much longer than changing the oil.
Great move going to the mini starter!
Old May 16, 2009 | 10:28 PM
joe wilson's Avatar
joe wilson
Thanks guys, you've given me the confidence to get the job started. Just waiting to get a day or two off from work and figuring out a way to get the car high enough in the air (I'm kinda big) to work under it.
To 85 Vette starter
