So my car is throwin h32 and h44. I am almost 100% sure its egr either not opening, or getting stuck.
As the car starts it idles cold, once it gets a little warm the idle starts to have issues until the check engine light comes on. than it runs fine, but with poor gas mileage.
I read a bunch of old threads about issues people had and the answers i got from them were, it could be due to a faulty EGR Sol, EGR valve or EGR Temp Sensor. The valve can be tested by a mini vac as a few people had said. Is there a way to test the solenoid? Also which temp sensor is it talking about? Is it just like the thermostat or is there a sensor close to the egr valve?
Jason
Jason
People delete EGRs all together and don't have issues with it running weird....It throws a code yes, but other than that, no issues even on heavily modded motors.
Quote:
i agree no problemOriginally Posted by Sorry Officer
get rid of egr all together.,. do the bt pass and for get it..
The EGR not opening will not affect the idle. Also, The EGR solenoid does not energize when the car is idling anyway. I doubt that your problem is with the EGR unless it's stuck open. Hook a piece of hose directly to the EGR port. You can suck on the other end and see if the egr is moving in and out.
