"Brake Pressure" light question
Old May 17, 2009 | 02:29 PM
Shaun R's Avatar
Shaun R
Default "Brake Pressure" light question
Light came on the other day but everything is checking out just fine. System was recently flushed, no leaks, no air in the system, plenty of fluid, MC rebuild less than 10K ago, pedal feels just fine.
Everything is leading me to just the switch being bad but from what I found switch has been discontinued? Anything else I should check before I go hunting for one of these things?
Old May 18, 2009 | 12:05 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
there is a rod that pushes up on this spring and pin./ check to see that your pin goes back to the neutral position before you waste time and effort on a swtch.
