Power Window
Old Feb 5, 2002 | 07:10 PM
dppeaden's Avatar
dppeaden
Default Power Window
I need a little help. Does anyone know how to calibrate the window? I replaced the power track and it is not quite right, it doesn’t make good contact with the seal. :confused:
Old Feb 5, 2002 | 07:40 PM
lead foot 85 vet's Avatar
lead foot 85 vet
Default Re: Power Window (dppeaden)
I didn't see the year in your post but with mine you remove the the door panel and there are three nuts on the window mount that you loosen, ajust the window, check alinement, and then put it back to gether. you might have to ajust it several times to get it alined right. good luck
