Hard to turn over
Old May 18, 2009 | 10:44 AM
garyjbova2's Avatar
garyjbova2
Navigator
Default Hard to turn over
My 89 C4 has been giving me a time. When the key is turned sometimes I get the solenoid click. Sometimes after a couple of tries it'll turn over. It almost seems to be temperature dependant. Is there a switch in the console, triggerd by the shifter that could be going bad? I cleaned the battery cables. The lights do not noticibly dim when attempting to start. Also after it warms up it runs like there is a cam in it, kind of lopes between 600 and 1200 rpm. The computer says I'm getting 29 - 30 mpg. I really don't want to screw that up.
Thanks,
Gary
Old May 27, 2009 | 07:07 AM
pcolt94's Avatar
pcolt94
Sounds like 2 separate problems to me. The solenoid on the starter is probably bad. Either rebuild it or replace the whole starter, sounds like a simple problem.
As for the lopping, on that year vintage vette the first thing that comes to mind are the injectors. I’ll bet a new set would do wonders for that car all the way around.
Old May 27, 2009 | 08:15 AM
garyjbova2's Avatar
garyjbova2
Navigator
Thanks for your reply. While flogging these problems, I changed the dist cap, when I pulled the coil to swap it, the bottom was all carbon tracked. I believe this was the original, so I changed it. Presently the vehicle is up on ramps to pull the starter. We've had so much rain in the past week I haven't had a chance to attack it. It looks like a major pain! The exhaust has to be dropped on that side, and you know one of the studs is going to break off.
Gary
Old May 27, 2009 | 11:22 AM
pcolt94's Avatar
pcolt94
If your saying you are going to drop the exhaust to get at the starter hold on. Although it looks tight it does come out easier than you think, it just looks like it won’t come thru. Disconnect battery before removal.
If my assumption is wrong, please disregard.
Old May 29, 2009 | 02:49 PM
SunCr's Avatar
SunCr
Assuming stock, no reason to drop the exhaust to R & R the Starter.
Idle surge (assuming it's still there) could be a couple of things: Vacuum/Exhaust leak - failure to respond to a/c request - leaking/plugged injectors. I'd scan it while the problem is occurring.
Old May 30, 2009 | 08:56 AM
ddahlgren's Avatar
ddahlgren
Dirty or bad IAC??
Old Jun 1, 2009 | 11:44 AM
SunCr's Avatar
SunCr
With a surge, I doubt it. The ECM is moving the IAC for a reason - you need to find out why and a scan should give you some clues.
To Hard to turn over
