Head Gasket Choice
Old May 24, 2009 | 02:57 PM
steven mack's Avatar
steven mack
All your car manufacturers use multi layered steel gaskets. These help with detonation and the use of dissimilar metals.And also rotting out,or blowing out due to high compression,which all the car makers are running for emissions.
Old Aug 23, 2019 | 10:31 PM
Tvette99's Avatar
Tvette99
Default Felpro 7733PT2
Originally Posted by jfb
I have always used the Fel-Pro teflon coated head gaskets and they last a long time. I told my mechanic I'd pay the extra money for the teflon coated gaskets and when he learned how long my gaskets lasted, that is all he uses any more. Non coated gaskets never lasted more than 2 years on my 87 which I drive every day. The teflon gaskets last more than 6 years!
Im wondering if 7733PT2 is teflon coated as i tried to find it online and cant seem to find it ?
Old Aug 24, 2019 | 03:25 AM
GregMartin's Avatar
GregMartin
People I trust told me to use Fel-Pro FE1010 head gaskets with aluminum heads. So that’s what I did and I haven’t had any problems.
If you are interested in calculating compression see below.
Gasket bore​​ 4.166”
Compressed Thickness​ 0.39”
Old Aug 24, 2019 | 10:37 PM
jv9999's Avatar
jv9999
Originally Posted by Pete K
I have run the 7733pt2's on every small block I have built. It is twice the quality you need.
They work, they are cheap, and reliable.
Buy them. You wont be sorry.
I agree. I've also used them on several L98s without issue.
Old Aug 25, 2019 | 02:37 AM
GregMartin's Avatar
GregMartin
Do they have copper combustion rings? I’ve heard the ones with the steel ring are ok for cast iron heads but will Brinell Aluminum Cylinder Heads.
