LT1 Cooling System Sealer Pellets
Old Feb 5, 2002 | 09:57 PM
steve bavaro's Avatar
steve bavaro
Default LT1 Cooling System Sealer Pellets
Changing out the cooling system anti-freeze. Have you ever used the GM cooling system sealer pellets p/n GM3634621 ?
Old Feb 5, 2002 | 10:00 PM
RichS's Avatar
RichS
Default Re: LT1 Cooling System Sealer Pellets (steve bavaro)
I use them when ever I change the coolant on a Vette.
Old Feb 5, 2002 | 11:28 PM
champ's Avatar
champ
Do we really need these pellets? After changing my waterpump, I flushed the system and went back with a 60 (distilled water)/40 (antifreeze) mixture. What does the pellets do?
Old Feb 5, 2002 | 11:59 PM
steve bavaro
Default Re: LT1 Cooling System Sealer Pellets (champ)
That's what I am trying to figure out. The service manual calls for them, and I just wanted to see what all the boys are doing. I believe they are to take care of any small leaks before they become big ones. I do not believe they have any lubricting purposes at all.
Old Feb 6, 2002 | 04:34 AM
JasonL's Avatar
JasonL
I think they are purely to help stop small leaks. I have asked two Vette mechanics, one who I frequently race with, and both have told me to use the tablets or else small leaks might occur.
Old Feb 6, 2002 | 10:01 AM
GS-598's Avatar
GS-598
They are for sealing any small leaks. They are almost edible! Ingredients are something like tumeric, ground walnut shells, soda! They are reminiscent of the old mechanics trick of putting ground pepper in radiators to stop leaks.
Dennis
GS*598 :cheers:
Old Feb 6, 2002 | 11:00 AM
tdock's Avatar
tdock
I thought it also had something to do with protecting the aluminum, being a porous metal, the pellets help to seal the surface and keep the dexcool from eroding it.
Old Feb 6, 2002 | 11:09 AM
steve bavaro
Default Re: LT1 Cooling System Sealer Pellets (tdock)
Could be on later model vett's. I have a 94 LT1 and dexcool was not used on that year model. Just a 50/50 mix of ethyelene glycol.
Old Feb 6, 2002 | 05:03 PM
kkonen's Avatar
kkonen
The switch to Dexcool was made sometime during the 95 model year. My car, manufactured in Novemer 1994 (I think), does not have Dex-cool.
Old Feb 6, 2002 | 10:13 PM
VMAX451's Avatar
VMAX451
Default Re: LT1 Cooling System Sealer Pellets (kkonen)
Nothing to do with dex-cool. The pellets are used due to porosity in the aluminum head castings. They're only a few bucks from the dealer.
Old Feb 7, 2002 | 11:03 PM
steve bavaro
Default Re: LT1 Cooling System Sealer Pellets (Vince Ivanc)
I bought the pellets from GM, only $4.00. Will crush them up and install, thanks for the input .
Old Feb 8, 2002 | 01:56 PM
TPFKATK's Avatar
TPFKATK
Vince is correct. My mother in law has a Caddy with a what is known as a porous casting. The anti-freeze actually weeps through the side of the block near the head. It the the weirdest thing I have ever seen. I use the pellets in it but it leaks anyway. It probably leaks maybe 6oz/month or less, almost nothing. I am sure the pellets also are supposed to help seal head gaskets, radiators etc. The factory service manual for the caddy addresses the porous casting.
Harold
To LT1 Cooling System Sealer Pellets
