1986 Alarm Question
Old May 20, 2009 | 11:40 AM
86STAR's Avatar
86STAR
Default 1986 Alarm Question
Here is the history. I brought the car (project) last year. It did not have a door key. In a moment of Corvette insanity, I locked the doors and set the alarm. Of course when I got the door open, the alarm went off. I finally pulled the connector off the horn (much to the delight of the neighbors). I got the keys made for the door and thought that would turn off the horn, but everytime I plug the horn connector back, it keeps "honking". I am sure I am just missing something, but can't figure it out. Any ideas? Of note, the car starts and runs...but I can't hook up the horn without the "amazing honking horn".
Old May 20, 2009 | 12:16 PM
my83432's Avatar
my83432
Is it one long beep or is it broken up? There is a switch the the door you should be able to use the key to lock and then ulock the door and shut the horn off. Did you try both doors?
Old May 20, 2009 | 12:28 PM
RWDsmoke's Avatar
RWDsmoke
On my 86 you have to turn the key in the opposite door that set off the alarm.
Old May 20, 2009 | 01:53 PM
86STAR's Avatar
86STAR
It is broken up. I will give th passenger door another try.
Old May 20, 2009 | 11:11 PM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Both doors have a alarm switch.If one side is bad the other will shut it off.
You can replace the drivers side door switch with a new one to fix the problem.
My former 86 had the same problem.Since the drivers door was used most often it wore the switch out.I had to go to the other side to shut it off.
It was annoying so I got a new switch for the drivers door and it solved the issues.
Also,to the OP,if you dont want to ARM you alarm,dont use the power door locks to lock the doors.Get out of the car and manually lock it by pushing the lock in the door panel by hand.
To see what I mean,open the door and watch the security light on the dash flash.
Hit the power door locks to LOCK and watch the light freeze in place on the dash.Thats it arming itself.
Unlocking it with the power switch disarms it(security light flashes again) before you shut the door and walk away.So when having problems with the alarm,and horn,just lock the door manually and it wont arm,until you fix the problem.
Also turn both door key holes side to side to lock and unlock,and remove key straight out of the keyholes if still having problems.The key can sometimes come out a little bit sideways keeping the alarm still active.
Old May 21, 2009 | 12:19 AM
ant-knee470's Avatar
ant-knee470
Is the Sercurity light lit up solid on the info center?
If it is,
The problem is in the doors or hatch ( Security switches ).. But if the security light is not solid, I would think the problem is in the horn wiring.. Since the car is starting it makes me wonder if the alarm is set. I beleive if the alarm is set the car should have a no start situation..
Old May 21, 2009 | 07:53 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Info for the forced entry alarm is the first part of this PDF. Should shed some light on where your problem is, but it does sound like the door switch.
http://members.shaw.ca/dankai/Vats%20Electrical.pdf
Old May 21, 2009 | 10:27 PM
86STAR's Avatar
86STAR
I really appreciate all the input. I have been out of town all week, but will be back in the car on Saturday (I few parts arrived and can't wait to install them) Believe it or not the "project" is starting to look pretty good. I will be checking out everything all of you have suggested. I will let you know how everything works out. Thanks again!
To 1986 Alarm Question
