1990 esc problem
Old May 20, 2009 | 10:51 PM
trader vic's Avatar
trader vic
8th Gear
Default 1990 esc problem
with codes clear the minute i start the car it shows a code 43 does the esc or ecm detirmin the voltage delivered to the knock sensor
what range should the voltage be i have read 5.5 mine has 12 volts the only way i can drive the car is in open loop with with the wire from the new ignition module to the esc disconected along with the ox and knock sensor and the timing bumped up to 10 degree
