Idle issues
Old May 22, 2009 | 12:57 PM
Hanny93's Avatar
Hanny93
Default Idle issues
I have a 93 auto, no mods. The idle has started to fluctuate after I have driven the car a while, 20- 30 min. No engine light, I have not checked for codes. The car runs great, no change in milage or anything.
Any ideas? Thanks for the help.
Old May 22, 2009 | 01:56 PM
Hanny93's Avatar
Hanny93
Default opti
From some of the reading I have been doing this looks like it could be opti related. Has anyone used the opti sold by summit?
Old May 23, 2009 | 10:09 AM
josephf31's Avatar
josephf31
Default Very
likely the injectors are bad, run an ohm test (many articles on the subject if you do a search)
Old May 23, 2009 | 10:21 AM
engle1147's Avatar
engle1147
Could be a bunch of things.....you should check for codes first. Most autoparts stores will do this for free.
A basic tune up might do some good if she's been neglected. Things such as filters, cleaning the carbon off inside the throttle body (use throttle body cleaner) and idle air control pintle and check or you could be a plug problem (check gap and burn)....other things to consider:
Could be dirty sensors
Could be clogging cats
As mentioned above it could be an opti spark related issue
Good luck
To Idle issues
