zero oil pressure
Old May 22, 2009 | 09:23 PM
garycr14's Avatar
garycr14
Default zero oil pressure
is there anything beside an oil pump failure that would give me 0 oil pressure?
The 383 stroker lt1/lt4 has about 20k on the clock.
Old May 22, 2009 | 09:40 PM
engle1147's Avatar
engle1147
The oil pump pickup might have a problem...might be blocked or loose.
Old May 22, 2009 | 10:10 PM
John A. Marker's Avatar
John A. Marker
Can you unscrew the oil cap on the valve cover and see if the rockers are getting oil? If they are, the problem might be the oil pressure sending unit.
Anything that you did just prior to zero pressure? Or did it just happen?
Old May 22, 2009 | 10:57 PM
No Go's Avatar
No Go
What about a broken oil pump drive stub...the part that takes the place of the distributor.
It is made of plastic and held by one bolt...MORE used to sell a metal reinforcement incase of plastic failing (I pulled my 85,000 original out with a crack).
Hopefully it is just a bad sender...
Good luck.
Old May 22, 2009 | 11:28 PM
garycr14's Avatar
garycr14
Don't need to remove the covers, you can hear the rattling
Old May 22, 2009 | 11:32 PM
garycr14's Avatar
garycr14
No, I was just driving home from work and the check gauge light came on, unfortunitly I didn't hear the noise until I was pulling up the drive. I hope I didn't cause any serious damage!
Old May 23, 2009 | 03:27 PM
TWISTERUP's Avatar
TWISTERUP
Good luck.
Above is one possibilty or it's possible the pickup may have come loose from the pump (just a press fit)---years ago I tack welded the pickup in place--I don't know whether all builders do that today though JMO
Old May 28, 2009 | 06:05 PM
TWISTERUP's Avatar
TWISTERUP
Had a chance to remove the oil pan yet ?
Old May 29, 2009 | 01:51 PM
garycr14's Avatar
garycr14
I had the car towed to the shop yesterday, and should have an idea of what is up this morning. I just didn't have the time to explore the possibilities. If I knew what to expect I could have dropped the pan and delt with it, but I was getting too many suggestions from the different people I talked with. I will post the outcome as soon as it is determined.
Thanks!
Old May 29, 2009 | 09:15 PM
No Go's Avatar
No Go
Bummer...
Hope you realize the stub oil pump drive I'm speaking of goes in thru the intake side...no reason to drop the pan.
Good luck!
Old Jun 1, 2009 | 12:53 AM
garycr14's Avatar
garycr14
Bummer...
Good luck!
The pan was pulled, and the gear on the drive was worn excessively, metal fragments in the oil & filter, pulled the main caps /rod caps off - the bearings have been damaged slightly. The intake will be pulled, the oil pump drive replaced as well as all the other components along the way, and the bearings will be replaced as well. Things are not real good, but hope to have it back on the road by the end of the week.
Thanks,
Gary
Old Jun 1, 2009 | 09:25 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
One of the reasons I'm going to a drysump, is the quality of the pumps now days.
Which pump did you use?
Old Jun 1, 2009 | 06:41 PM
No Go's Avatar
No Go
By drive gear, do you mean the stub driveshaft? That gear can only be accessed by going thru the intake.
This may not be a oil pump issue whatsoever. SBC oil systems are one of the most reliable around...
Old Jun 3, 2009 | 04:49 PM
garycr14's Avatar
garycr14
It was a SBC high volume... The pump did not fail, the stub gear was the problem.
Old Jun 3, 2009 | 04:51 PM
garycr14's Avatar
garycr14
Yes, it is the gear on the stub driveshaft. The pump itself was fine, and was replace by removing the intake.
Gary
Old Jun 24, 2009 | 09:34 AM
catlettlt1's Avatar
catlettlt1
I had the same issue on my former LT1 at 10K miles. I have an LT4 now
but it still worries me I'm going with the comp cams composite gear.
High oil pressure will eat the oil pump drive gear up.
To zero oil pressure
