Exhaust cut outs?
But, the down-firing config works for me!
The main problem is that most of the time they make more noise and don't deliver the results that some folks are after. There is far to much detail to go into here about tuned exhaust lengths, but basically you could only tune your car to run optimum on either full length or cutout length, and most of the time there will be negative results for the length that is un-tuned. To most folks, they wont care about the technical side of it, cause it sounds mean and satisfies them, whether or not they actually gain anything from it.
Exhaust open and just live with the results when it's closed?
typically a higher flowing exhaust leans it out.
I don't know how the C6Z06 deals with it.
The computer may receive a signal, or they open at set rpm so it's built into the map(s).
When plugged up, I like the sound, and it has a bit of a bite, but as far as performance mufflers go, they're pretty quiet. The below is an in-car video of what they sound like going down the track. (That video is with them plugged), if you unplug, naturally is more of an open header sound.... a little quieter though because the exhaust is still running through the pipe and out the back.
I considered exhaust cut-outs before, with manual ones, I didn't like the idea of getting under the car to plug/un-plug at the track..... and with the electrical ones, I had heard after a few months, they tend to stick sometimes..... I don't know if that is reality or not, but it was enough to deter me. The Warlock Muffler route was cheaper too.
good luck with whatever you choose !
Vid with warlocks plugged (383 C4 11 second pass)
http://www.youtube.com/watch?v=4fzWp...e=channel_page
Warlock Muffler Link:
http://www.holley.com/50560FLT.asp
This may be just what I was looking for. I've seen these before but forgot about them. I am currently running headers with straight pipes but I was thinking of adding some bullet mufflers at the back to quiet it down some. The warlocks though would quiet it and still allow me to run straight pipes when I wanted. I'm going to see if I can find some video on them outside the car. Don't have any do you?
I used to have in-car video with them unplugged, but somehow have lost it..... I don't know where it went.
I will say, this track is in a little dug-out valley, so sound kind of travels a bit......
On my set-up, it is worth a tenth & mph to un-plug..... this was only a 6000 rpmp motor, I think more motor could have made a bigger difference, but not sure.
Same motor, but just 3.07 gears, in the other vid I had swapped to 3.45's.
http://www.youtube.com/watch?v=AylUw...eature=channel
