4plus3 trans.no 2nd gear switch.Help!
Old May 24, 2009 | 06:34 PM
Richardfg7's Avatar
Richardfg7
2nd Gear
Default 4plus3 trans.no 2nd gear switch.Help!
1986 w/4plus3 trans. have problem w/overdrive not always coming on.I bought a book "101" projects for your corvette" it shows to place a jumper wire on the 2nd gear switch to trick the computer to think the trans. is in 2nd gear all the time. The result being basically w/use of the O.D. cancel switch an 8 speed trans. Problem is my unit has just one switch on shifter cover...reverse lights! There is no evidence of ay wires for switches on the harness??? Any input id be very greatfull. firstgear7@msn.com
Old May 28, 2009 | 05:51 PM
rwynn's Avatar
rwynn
My 86 4+3 just starting doing this. I checked the fluid level and ended up having to put a quart of fluid in it. It comes on more often now. I just did it today so I will monitor and see it fixes it all together. I need to change the filter also. I would start there. You have to jack the car up to check the fluid though.
Old May 28, 2009 | 07:27 PM
tequilaboy's Avatar
tequilaboy
86 4+3s don't have any gear position switches.
First gear, first o/d and 4th gear are detected by the ecm by dividing rpm/mph and comparing the result to threshold values.
Old May 28, 2009 | 08:15 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
do not use OD in first! you will ruin the friction material, and it will slip and not move the car.
Old Jun 24, 2009 | 07:45 PM
rwynn's Avatar
rwynn
I finally got mine fixed! It was the overdrive realy was bad and the wires were also stripped and shorting out. Tape the wire and replaced the switch and now the overdrive works like new.
To 4plus3 trans.no 2nd gear switch.Help!
