Poor man's timing wheel
Old May 25, 2009 | 07:14 AM
Dolfan's Avatar
Dolfan
Default Poor man's timing wheel
I was thinking since I have the heads off and can accurately measure when the cylinders reach TDC, before I put the heads on why don't I put masking tape onto the balancer and as I rotate the engine I can mark the positions for TDC?
I figure it should take some of the guess work out of adjusting the valves. And once I have the first 4 marks I can adjust the valves using the technique to do two at a time, like #1 and #6 first, then on to the next.
Make sense, seems like it should make the job easier!
Old May 25, 2009 | 08:05 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
When I built my motor, I painted lines on the balancer. It does come in handy and is there for future use, too.
Old May 25, 2009 | 10:27 AM
Dolfan's Avatar
Dolfan
Yeah, maybe a little paint for a permanent solution would be a good idea.
To Poor man's timing wheel
