Belt Jumping off??
Old May 27, 2009 | 12:56 AM
1CLNLS1's Avatar
1CLNLS1
1st Gear
Default Belt Jumping off??
Hey guys new to the forum lol just baught a 97 with 30k on it.. its an auto but the belt started to slip off?? any ideas thanks
Old May 27, 2009 | 02:29 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Might check to see that the pulleys are all in-line with each other.
Someone here might have a trick to measure this alignment
Old May 27, 2009 | 07:56 AM
runner140*'s Avatar
runner140*
Take a look at the condiction of the belt. Might be a good time to replace it. Also, grab the belt tensioner and make sure it puts plenty of tension on your belt OR replace it.
Old May 27, 2009 | 08:01 AM
WW7's Avatar
WW7
This sounds like a weak belt tensioner...WW
Old May 27, 2009 | 08:03 AM
engle1147's Avatar
engle1147
Also have a good look at each of the pulleys to ensure the components they mount to are tight and that the pulleys themselves are are not loose or damaged. Might want to go back on with a "new" belt and double check that it is properly installed into the groves before starting.
Old May 27, 2009 | 09:01 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
A 97? Might want to post in the C5 Section for additional help advice.
To Belt Jumping off??
