Need help.. 1991 Engine harness question>
Old Feb 7, 2002 | 09:21 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Need help.. 1991 Engine harness question>
I have an 1991 enging harness I am installing in my 89.. (dash is 80% done) but I am not sure on a connector.
The connector iin question is oval shaped and is white, it has one wire that is green going to it. It also looks like the same connector for the Oil Pressure Sender/switch, but that one is a 3 wire and grey. The Connectro in question is also near the Oil Pressure connector. can any one tell me either what it is for and where it goes?
Old Feb 7, 2002 | 11:13 AM
Red91C4's Avatar
Red91C4
Default Re: Need help.. 1991 Engine harness question> (-=Jeff=-)
Jeff, my 91 has 2 sending units at the rear of the engine, one of them has the single green wire connector you are talking about. I believe that it is a fuel pump enable wire (shuts pump off with loss of oil pressure).
Monte
Old Feb 7, 2002 | 11:33 AM
-=Jeff=-'s Avatar
-=Jeff=-
Default Re: Need help.. 1991 Engine harness question> (Red91C4)
Thanks!!!
To Need help.. 1991 Engine harness question>
