Cold Air Intake Test Results
Old May 30, 2009 | 04:48 PM
tequilaboy's Avatar
tequilaboy
Default Cold Air Intake Test Results
I finally had a chance to try out my Bf-109 inspired cold air intake/supercharger inlet.
Here are a couple quick pics:
Results for 72 F ambient temperature:
Under cruise:
Blower discharge air temperature dropped by approx. 30 degrees F. From a typical value of 130F to 93-96F..
Under Boost:
Blower discharge air temperature dropped by about 65 degrees F under boost. From typical peak value of 270 F to 205 F at 10 psi in 2nd gear. No knock retard or knock counts present with 26 degrees advance.
Stationary idle/low speed running:
Blower discharge air temperature stablized at approx. 100F. Typically this would approach 160-170 f for a sustained idle with the air cleaner mounted to the blower inlet.
The air cleaner will be relocated internally. This is only the first test, to determine feasibility and the impact on the charge air temperature.
Note: This was done with a $12 used ebay fender.
Old May 30, 2009 | 07:29 PM
mseven's Avatar
mseven
Pat, the gain in lowered temps in huge!! My only critique would be trying to hide it a bit more. Can you get a 180* from the inlet to go out underneath the blower/power steering and then out in front of the tire where the c. canister is located (lower portion of the front bumper cover where it connects to inner fender)?
Old May 30, 2009 | 09:55 PM
Vette Fast's Avatar
Vette Fast
The cold air intake does make a difference. Good luck with your project.
Old May 31, 2009 | 10:24 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
I have been trying to figure out what car came with turn signals that are the same height as the corvettes' without the running lights part. That way, you can free up some space where the running lights go to make a dual inlet from both sides. an aluminum sheetmetal "funnel" on both sides painted black would look symmetrical, and would need a baffle to lose any rocks or leaves, etc. when the car is shut down. maybe even a screen with a small wire that has a finger ring to pull it out and shake it clear occasionally then slide it back in.....The screen could be left out for HP runs, then reinserted for normal driving. Using the holes for the turn signals/running lights would allow you to use the existing factory holes, and give you the option to go back to stock if the need arises.
um, that air filter would indicate too much tequila if you left it that way.
after studying your pics for a sec, If I had those holes cut in MY hood, I would find a K&N filter tht would fit in the square inlet under the hood, and on the top of the hood, make a low profile air inlet, and use teflon or soft seal, and bolt it through the louvers with long screws through the gaps of the louvers maybe with either many small diameter screws (for strength) or sheet metal "straps" that go through the louver slots and release with Zeuss fasteners (quick release) on the bottom of the hood.
Old May 31, 2009 | 10:38 AM
c-4 lhozwalte's Avatar
c-4 lhozwalte
i live in arkansas and one trip @ night and that filter would be plugged solid with insects.that has to be a track only car is the onlything i can figure.looks crazy as hell but those results speak for themself.GO GO SNORKLE CHARGER!!!!
Old May 31, 2009 | 11:24 AM
tequilaboy's Avatar
tequilaboy
SNORKLE CHARGER! I like it.
Thanks for the feedback.
Of course, the point of this exercise was to determine how much there is to be gained by feeding the supercharger with cooler air, and if the gains would justify a more sophisticated/practical/aestheticly pleasing/permanent solution.
With the blower in the picture, it was never clear to me how much air heating was actually due to the compressor vs drawing hot under hood air near the exhaust header.
Now I'm motivated to make something work, but I'm not yet willing to modify the hood.
I was going to run without a filter for the first test, but since I have about a mile of dirt road to negotiate before hitting the pavement, I needed some kind of filter.
Since my original filter was easy to fit and cleared the tire, I just left it on for the test drive, since I wasn't really concerned about building any ram pressure at this stage. I was also concerned about sucking in birds/bugs or other debris, so I figured the filter was a good thing to have, despite the appearance.
Its an easy swap to revert back to the normal fender arrangement, so this may wind up being reserved for track days.
I'll work on packaging the filter inside a housing just inside the fender and ducting to the blower. I have a coffee can that should do the trick. This should result in some ram pressure from the snorkel and hopefully minimize heat soak to the filter element and housing since they will be a good distance from the header.
Old May 31, 2009 | 11:35 AM
Aardwolf's Avatar
Aardwolf
Very nice drop in temps!
Could this work for air intake? Intake air instead of brake cooling:
The make different size and shape NACA ducts, they are around $20 and can be riveted in. glassed in, etc.
Old May 31, 2009 | 11:43 AM
rickneworleansla's Avatar
rickneworleansla
Nice photochop.
Old May 31, 2009 | 11:44 AM
c-4 lhozwalte
I know there is a formula for intake charge temp drop vs horsepower gain,but i dont know what it is.maybe someone will chime in on that.i know that some forced induction guys use two iat's one before and one after the s/c to help maximize fuel and spark maps.my guess they use stand alone cpu set ups.ill be watching to see what you come up with for a final set up.i like to race and for the track id use it the way you got it now,and then swap back to street mode set up the rest of the time.
Old May 31, 2009 | 11:45 AM
Aardwolf's Avatar
Aardwolf
Originally Posted by rickreeves1
Nice photochop.
Old May 31, 2009 | 11:52 AM
rickneworleansla
I think you should try a triple air intake.
Old May 31, 2009 | 11:55 AM
mseven's Avatar
mseven
Old May 31, 2009 | 12:06 PM
rickneworleansla
Originally Posted by Aardwolf
Ok sorry, maybe I jumped the gun here. I just ASSumed no one would actually do something like this.
Old May 31, 2009 | 12:09 PM
Aardwolf's Avatar
Aardwolf
Dang, now animate it so it spins around.
Old May 31, 2009 | 12:44 PM
rickneworleansla
Old May 31, 2009 | 01:02 PM
Pwnage1337's Avatar
Pwnage1337
Old May 31, 2009 | 01:40 PM
ChrisWhewell's Avatar
ChrisWhewell
Nice work.
My 93 fenders are louvered and I've pondered cutting out the depressions and installing a tapezoidal funnel duct / collector over them on the inside of the fender for an air intake, but is remains only a thought.
To Cold Air Intake Test Results
Old May 31, 2009 | 02:13 PM
tequilaboy's Avatar
tequilaboy
I pulled out the battery tray and the filter now fits inside the fender, just inward of the snorkel.
I Just have to work on the housing to enclose the filter and attach to the snorkel now for the full effect.
Update:
Filter is now enclosed internally and is isolated to the snorkel. An old golf bag cover with a 3 inch hole cut for the snorkel, a 3-4" pvc adaptor to form the coupling to the snorkel and prevent collapse of the bag and some zip ties to seal up around the duct with the air cleaner inside, a little like the improvised Apollo 13 CO2 scrubbers...
Went for a quick drive at tonight's 60 F ambient temp. Blower discharge air temps hovered between a cool 80 F and 86 F with the internal filter and bag arrangement. So it looks like a 20-25 degree rise over ambient is repeatable.
Old May 31, 2009 | 03:37 PM
ChrisWhewell
Update:
Did you relocate the battery ?
Old May 31, 2009 | 03:46 PM
tequilaboy's Avatar
tequilaboy
Yes,
The battery was relocated several years ago to the passenger side storage compartment to improve weight distribution.
Since this had already been done, it made this experiment much easier.
