89 l98 build
Old May 30, 2009 | 09:58 PM
kitttransam's Avatar
kitttransam
Default 89 l98 build
I'm rebuilding the engine for my 89 vette. Looking for some suggestions. I already ordered the engine kit and I'm getting flat top pistons. I'm racking my brain on what cam to get. I want something better than stock but I want to pass smog test also. I'm also on a budget and I don't want to have to do any tuning. I'll listen to any and all sugestions.
Old May 31, 2009 | 02:34 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
If you use flat top pistons, you shouldn't use the 58cc heads it came with. I did that in my 86, and I have to use the expensive gas all the time. when it's hot and you are in a hurry, the knock sensor retards the timing a lot
Old May 31, 2009 | 08:13 AM
engle1147's Avatar
engle1147
Yep you'll want to use the (expensive) higher octane stuff once you crank the compression up with the flat tops.
I'm in the process of doing my own "Operation: Budget L98 Rebuild & Refinements" and I've selected a flat top piston (with 4 valve reliefs) as well....see pics below. The block has been freshened up to .040 over stock and I'm going in with a ZZ4 cam which doesn't technically require a "re-tune" from a stock chip. I've been running a "mail order tune" but am having a re-burn done anyway to ensure close to maximum effeciency/effectiveness for the build. A "tune" can also desensitise the knock sensor.
"Operation: Budget L98 Rebuild & Refinements" write up (with tons of pics) will commence once the project is complete.....here is a glimpse.
Old May 31, 2009 | 11:06 AM
kitttransam
Thanks for the info. I was thinking about the zz4 cam. Now I am definately getting it.
Old May 31, 2009 | 12:13 PM
Master__Shake_'s Avatar
Master__Shake_
Ouch, those older pistons look horrible.
Before you go swapping in a camshaft, what modifications are you going to do to the motor other than pistons? If nothing, the ZZ4 cam will work, along with the XR258HR-12, X4260HR-11, or even the XR252HR-10 for improved low-end torque over the stock L98 cam. When building around the stock intake, it's important to remember that more RPMs = less power, so you build to make peak power @ or around 4500 RPMs. Anything higher than that, unless the runners are aftermarket/siamesed, will have no effect on power.
Aftermarket intake/runners and you're looking at longer durations, most notably the LT4 hotcam - but that requires a tune.
To 89 l98 build
