Backfire when starting
Old Jun 3, 2009 | 03:38 PM
betyelou's Avatar
betyelou
Default Backfire when starting
1996 LT1, 85K. Auto. Car starts very strong however the past month every once in a while on a cold start I get a backfire. Does not happen every start but more often after rain. No misses and runs strong. This is a very small backfire. Any thoughts, original opti, original injectors.
Thanks in advance for your ideas.
Old Jun 3, 2009 | 08:41 PM
betyelou's Avatar
betyelou
Any thoughts.
Old Jun 3, 2009 | 10:20 PM
MikeC4's Avatar
MikeC4
Could be anything, but at 85K miles, I would recommend a tune-up.
Opti's are good for approximately 100K miles, so I would consider replacing it, along with :
-water pump
-plugs/wires
-clean IAC
Since you said that the backfire happens during wet conditions, it might be moisture in the Opti which is causing arcing.
EDIT:
also check the coil wire for tight connection at coil and Opti.
To Backfire when starting
