New QA1 coilover kit out
Old Jun 4, 2009 | 09:33 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default New QA1 coilover kit out
Thought I'd post this for those who don't have the coin for a set of Penskes.
They use the Hardbar mounts that I'll be using for my install
Originally Posted by ghoffman
Yes, Vansteel is now selling a new kit for C4's, and soon, a similar version for C5's and C6's. We (Hardbar) designed the upper clevis, and the lower rear C4 mount and did dyno development on the shocks. Best bang for the buck you can get either in a single or double adjustable. They are 100% each dyno tested, and are 100% made in USA and cost less than the competition.
http://www.vansteel.com/index.cfm?fu...&SubGroup=1906
Old Jun 4, 2009 | 09:49 AM
jmrl98's Avatar
jmrl98
These guys are making them for QA-1? I love my regular QA-1s...
Old Jun 4, 2009 | 11:06 AM
383tpimachine's Avatar
383tpimachine
thats sick
i want some
my stock 85 bilsteins are dying
Old Jun 4, 2009 | 11:07 AM
383tpimachine
and then i go to the site and none for 84-87
Old Jun 4, 2009 | 12:17 PM
BrianCunningham
Narrow towers on the early cars make it a problem.
Old Jun 4, 2009 | 12:27 PM
LD85's Avatar
LD85
84-87 is more complicated but Exotic Muscle makes direct fit for 84-87
Or you can do what i did.
see sig
Old Jun 4, 2009 | 12:31 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
Old Jun 4, 2009 | 12:36 PM
87L98Z52's Avatar
87L98Z52
see sig
What size spring did you use?This kit uses a 2.25" and 2.5" hyperco coil over spring.
Those might fit the factory upper mounts on the early 84-87 with some bending.
Your springs that you used look much wider.
Old Jun 4, 2009 | 01:28 PM
LD85's Avatar
LD85
400# in the front and 275's in the rear,
Coil-Over Spring, 2.5 in. Inside Diameter, Silver Powdercoated
http://store.summitracing.com/partde...0&autoview=sku
Old Jun 4, 2009 | 01:30 PM
383tpimachine
wow thats some good stuff. do mine next?
Old Jun 4, 2009 | 01:34 PM
87L98Z52's Avatar
87L98Z52
Do you know what the outside diameter is on yours?Why do those look wider then the ones on the vansteel qa1 kit above?
I know the ones on the kit are 2.25" and 2.5" inside dia springs.
Same ones used on the drm bilstein coilover kits i believe.
Old Jun 4, 2009 | 01:40 PM
383tpimachine
cant find exotic muscle website
Old Jun 4, 2009 | 01:51 PM
rickneworleansla's Avatar
rickneworleansla
Try here..
http://www.exoticmuscle.com/
They may be working on the site. I am currently unable to get to the parts sections.
Old Jun 4, 2009 | 02:07 PM
383tpimachine
ditto
cant get past the pics
Old Jun 4, 2009 | 02:29 PM
Mojave's Avatar
Mojave
I saw these in the other coil over thread in the AX section, but I wonder how these will work with track spring rates (ie 600+ in the front, 400+ in the rear). I'm tempted, but I'd hate to blow $1700 to find the shocks suck and don't have enough adjustment range.
Old Jun 4, 2009 | 02:51 PM
LD85's Avatar
LD85
Just measured them, they are 3-5/8" od
Old Jun 4, 2009 | 03:16 PM
87L98Z52's Avatar
87L98Z52
Thanks man!
I wonder what the o.d is on the EM,DRM,and these VANSTEEL coilovers above.
Anyone have these that can measure for us?
To New QA1 coilover kit out
Old Jun 4, 2009 | 03:19 PM
87L98Z52's Avatar
87L98Z52
Spoke to Paul at Vansteel,those are the kind of rates he uses on these for track cars.
Give him a call,he is a very cool guy to deal with.
He also told me if i wanted to go with these,he would work through any issues with me because i have a early 87 c4.
I guess he is looking for a guinie pig.LOL
Old Jun 4, 2009 | 03:22 PM
Mojave's Avatar
Mojave
Thanks for the heads up; I may give him a call.
Old Jun 4, 2009 | 04:30 PM
RacerX70CC's Avatar
RacerX70CC
That's called "field engineering" in GMspeak
Van Steel good people to deal with
