Brake master cylinder difference
Old Jun 5, 2009 | 06:13 AM
Qiken's Avatar
Qiken
Default Brake master cylinder difference
Need to replace the brake master cylinder on my 89 due to leaking(at booster)
I had initially planned to hone out and insert a stainless steel sleeve and put in a kit.
I know 86 and 87 are the same,The 88 is a one off, 89 to 91 is the same but what confuses me is that I currently have two resivours on mine,however some sellers are selling master cylinders that have only one fluid resivour with a connector tube to the front inlet and state that these suit the 89 what is the difference?
Old Jun 5, 2009 | 12:49 PM
SunCr's Avatar
SunCr
'89 was upgraded (what it was I don't know) for the ZR1 which uses same. I'd stay with it - it's the brakes!
Old Jun 8, 2009 | 06:39 AM
Qiken's Avatar
Qiken
The current Mid America catologue shows the 89-91 AC Delco master cylinder as having only one reservoir,which is what the 86-87 looks likeI'm confused now on what I can use as a replacement..Any suggestion's?
Old Jun 8, 2009 | 08:18 AM
jimmers's Avatar
jimmers
My '90 has 2 reservoirs if that helps.
Old Jun 9, 2009 | 02:52 PM
SunCr's Avatar
SunCr
Picture isn't right and may only be representative - there are 2 - instead of risking it, try NAPA or somewhere else. These puppies are Aussie sourced so make sure you get the real deal.
Old Jun 10, 2009 | 03:17 AM
Qiken's Avatar
Qiken
Is ridiculous,yep PBR made in Australia, but cannot source them direct here,only from the U.S.
Bit like DBA vented Rotors,I thought it stood for "Disc Brake Australia",come with patented Kangaroo paw vents and saw them advertised in the U.S.Umm I thought,DBA ? Kangaroo paw technology?must be a sets from Australia.Contacted DBA Australia,who said They dont make them for the vette's,they are made by their subsiduary group in the U.S. ..you guessed it DBA"Disc Brakes America"
To Brake master cylinder difference
