Tall deck motor in C4?
Old Jun 5, 2009 | 06:39 PM
thetoy's Avatar
thetoy
Default Tall deck motor in C4?
Has anyone here put the Dart iron eagle tall deck block in a C4? If so what mods must be made if any for it to fit? My 440 just went boom last weekend and destroyed everything so I will be starting from scratch again. I'm thinking of doing a 461 cubic inch small block with a tall deck block.
Old Jun 5, 2009 | 11:03 PM
tpi 421 vette's Avatar
tpi 421 vette
Hey Tim, that really sucks to hear. Not sure how a tall deck would fit in our cars, but would be curious to hear it myself.
It sounds like the new AFR 235's will be out in the next few weeks, unless you are thinking 18 degree or 15 degree. But a tall deck would require a specific manifold for the tall deck and whatever heads you end up with. I haven't seen SBC spacers for a tall deck to use standard 23 degree manifolds on them.
Good luck with it!
Jim
Old Jun 6, 2009 | 01:13 AM
thetoy's Avatar
thetoy
Good luck with it!
Jim
If a tall deck will fit I was thinking of a 461 cubic inch small block. I am debating on the allpro 23 degree heads they flow around 350 cfm's. I want the new 235 afr's but I don't want to miss anymore races than I have to and I can get the allpro's in two weeks. My engine builder said they have spacers for the intake to fit. Depending on how much this cost I will probably get a hogan intake.
Old Jun 6, 2009 | 01:34 AM
tpi 421 vette
Hey Tim, do you know who makes spacers. I have never found any, and would be curious to know who makes them. Thanks.
Oh... Tony made it sound like the new 235's could be out in the next several weeks.
Old Jun 7, 2009 | 10:36 PM
thetoy's Avatar
thetoy
No one here has done one yet?
Old Jun 14, 2009 | 08:37 AM
yedister's Avatar
yedister
Dart sells intakes designed for the tall deck block, and spacers (PN 622100002) could be use with any standard manifold, they will require machining.
Yedi
Old Jun 14, 2009 | 10:34 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
well, you can always get a new hood with the cowl induction..................
Old Jun 14, 2009 | 01:49 PM
tpi 421 vette
Yedi
Thanks. I knew there are specific tall deck manifolds, but didn't know about the spacers for SBC's. Good info!
Old Jun 15, 2009 | 12:08 AM
thetoy's Avatar
thetoy
Allpro is making the spacers to match there heads to my miniram. There head uses a 1207 intake gasket.
Old Jun 16, 2009 | 12:33 PM
yedister's Avatar
yedister
Have your Miniram and heads flowed together because the miniram will need to be ported. There is one major problem with the Miniram that no one seems to really understand, the Plenum chamber is limited to how much air it can support. Porting the runners to flow more does not change the plemun size. There is a formula for calculating the plemun size to horsepower.
Old Jun 16, 2009 | 01:20 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
A miniram is a lot shorter than a tpi, so that should help you out a lot.
Old Jun 16, 2009 | 10:18 PM
thetoy's Avatar
thetoy
Well all the parts have been ordered for the 461 small block now. My builder was planning on flowing the heads and the miniram together and port as needed on the miniram. Does anyone make 2" or 2"1/8 headers for the C4's?
Old Jun 17, 2009 | 09:53 AM
BrianCunningham
EM has stepped headers.
Old Jun 17, 2009 | 12:30 PM
yedister's Avatar
yedister
Check with Dawson Racing Headers
To Tall deck motor in C4?
