"Passenger window switch trouble"
Old Jun 6, 2009 | 08:51 AM
34oSc's Avatar
34oSc
Navigator
Default "Passenger window switch trouble"
I did a search here, but couldn't find the answer, so I gotta bother you guys for some help.
My '94 vette had passenger window trouble, (motor came loose) I got it put in tight again, but I screwed up big time.
I didn't have the wires out of the way and I lowered the window and it pulled ALL the wires off the passenger's window switch...
I know, I'm a loser... there are 6 wires that go on it, I've got a schematic, but that's no help as it doesn't show me terminals...
Can anybody help a poor man out?
Old Jun 6, 2009 | 01:22 PM
gotta 94's Avatar
gotta 94
Remove the drivers door panel and look at switch with the wires connected.
Old Jun 6, 2009 | 01:33 PM
gotta 94's Avatar
gotta 94
Pull the drivers side out for review and match it up.
Old Jun 7, 2009 | 10:05 AM
34oSc's Avatar
34oSc
Navigator
I appreciate the advice, but on mine the driver's door switch is different than the passenger's... The driver's is a double switch, already been into it with no luck...
Old Jun 7, 2009 | 03:37 PM
RLG's Avatar
RLG
on my 90 :
gray wire goes to the single connector
reading from left to right(the gray wire will be directly across from number 1
1= Blk wire, ground
2 dark blue with white tracer goes to motor.
3 dark blue with tracer, this wire comes from your drivers door switch
4 Tan this also comes from door switch
5 tan ,goes to the motor
Old Jun 7, 2009 | 06:07 PM
formul89's Avatar
formul89
I literally just did this 15 minutes ago on my '94. Switch would go down, but not up. Sprayed some electrical contact cleaner into it and works great now.
From top to bottom:
Brown
Black
Blue
Grey
Orange
Blue/White
Old Jun 7, 2009 | 06:15 PM
Hooked on Vettes's Avatar
Hooked on Vettes
Pictures of Connector C1 and C2. Manual calls it a view of Harness Connector Face.
Connector C1
Pin A= Brown wire. Goes to Passenger side Motor
Pin B= Dark Blue wire. Goes to Passenger side Motor
Pin C= Black wire. Ground
Connector C2
Pin A= Light Blue wire. Goes to Driver side switch
Pin B= Tan wire. Goes to Driver side switch
Pin C= Yellow wire for Back Lighting Bulb
Old Jun 9, 2009 | 10:12 AM
34oSc's Avatar
34oSc
Navigator
IT'S FIXED!!!!!
Thanks to all here who offered help...
"formul89" had it exactly right and I've written the order of BOTH windows down so that maybe I can help somebody in the future.
You Guys are GREAT!!!
Old Jun 9, 2009 | 10:18 AM
formul89's Avatar
formul89
Originally Posted by 34oSc
IT'S FIXED!!!!!
To "Passenger window switch trouble"
