Coolent Resivore Cap
Old Jun 8, 2009 | 06:41 PM
MP6's Avatar
MP6
Default Coolent Resivore Cap
Should there be some sort of rubber or any type of seal on the inside of the cap? Mine is all plastic. I assume this is normal? Its a 92. thanks
Old Jun 8, 2009 | 06:46 PM
jimmers's Avatar
jimmers
I don't have any type of gasket on my '90 coolant reservoir cap.
Old Jun 8, 2009 | 09:20 PM
MP6's Avatar
MP6
thanks
Old Jun 8, 2009 | 11:37 PM
Calderone's Avatar
Calderone
me neither
Old Jun 9, 2009 | 01:13 AM
pologreen1's Avatar
pologreen1
NOPE coupeguy is right I just went and checked and sure enough there is one, and when you look at the cap you can see why it is there.
Old Jun 9, 2009 | 01:18 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
there is supposed to be a cork gasket. Otherwise, the coolant will splash up to the neck and the antifreeze wll wick out and leave a colored stain on the top of the reservoir. i went to a wrecking yard and went through about 16 reservoirs till I found a cap with a gasket.
Old Jun 9, 2009 | 01:38 AM
MP6's Avatar
MP6
could not having one cause the engine to run hot?
Old Jun 9, 2009 | 08:23 AM
jimmers's Avatar
jimmers
I went and checked again, and I don't have one. I've never had any issues with coolant splashing over the neck.
Old Jun 9, 2009 | 10:27 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Can't you still find them in the Motormite Help! section at your local auto parts store?
Old Jun 9, 2009 | 10:57 AM
josephf31's Avatar
josephf31
Default No
I doubt that would make much difference in operating temperatures.
To Coolent Resivore Cap
