California Super Ram Combo
Old Jun 7, 2009 | 04:25 PM
cumbercr's Avatar
cumbercr
Default California Super Ram Combo
Is anyone running this combination in CA? I'm curious about how you smogged and are you happy with the combination. With the exception of the cam, this is all CA legal.
383 Stroker
Lingenfelter 219/219 cam
Accel Super Ram intake
AFR 195's
24# Injectors
Old Jun 7, 2009 | 04:27 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Your going to need bigger injectors.
Old Jun 7, 2009 | 04:42 PM
slickfx3's Avatar
slickfx3
383 Stroker
AFR 195's
24# Injectors
I have 30's from Jon FIC
and that cam is old technology, Comp sells Fuel Injection cams that are bigger, My shop tells me the cats will scrub whatever emissions you have, they may over worktime, but don't fret too much.
farscape1a's Avatar
farscape1a
at least 36#ers or maybe even bigger. maybe 42's...
Old Jun 7, 2009 | 04:54 PM
Pete K's Avatar
Pete K
I wish someone would have told me 24# er's would not work.
I have been running them on the same combo for 14 years.
Interesting.
Old Jun 7, 2009 | 05:01 PM
farscape1a's Avatar
farscape1a
Interesting.
i was told by the guys at advanced induction with their 190 cc head job and custom cam (i forget the specs right now) that it would need 42#ers on a 383... is that too large an injector?
Old Jun 7, 2009 | 05:06 PM
Pete K's Avatar
Pete K
I cant speak for another combo, but my experience with my super ram 383 that stays below 6000 rpm has too much injector.
My buddy ran a mid 11 second 434 (superram) car with 5800 shift points had 36 pounders, and we could not lean it out enough.
Old Jun 7, 2009 | 05:14 PM
pologreen1's Avatar
pologreen1
I have a superram and bought inkectors from FIC for a stock to mild motor,FIC said 22- 24 is enough, because you can get a regulator and up them to full cap.
IMO many people go overboard with injector size. I think 24-30 is probably good for the 450 to if you are lucky some how 500 hp you might make.
Old Jun 7, 2009 | 05:54 PM
cumbercr's Avatar
cumbercr
The other cams I'm considering are the Comp Cam 260XFI or possibly the 268XFI. Keep in mind this is not being built for the track. The 260 would keep the low end torque TPIs are known for. Probably quite good for highway. The 268 moves the power band up at a slight loss on the lower end.
Old Jun 7, 2009 | 05:58 PM
cumbercr's Avatar
cumbercr
I bought the 24# injectors I have from Jon. He indicated they would get me to my goal of 400 Hp. I use an AFPR set at 47 psi for max flow and very good atomization. I know I'll never get the 450 to 500 I would like and still be legal in this state. But I can still have fun on the street.
Old Jun 7, 2009 | 06:21 PM
cv67's Avatar
cv67
St. Jude Donor '05
About any of those will work good, the 260 is a tad on the small side for the stroker. If you can work the SR over a bit. Not totally necessary but it will help;youll make tons of torque with that setup.
Old Jun 7, 2009 | 06:26 PM
cumbercr's Avatar
cumbercr
What would I do to the Super Ram to improve it?
Old Jun 7, 2009 | 06:32 PM
Mojave's Avatar
Mojave
I put 42# injectors on my 7K RPM 383, 450 RWHP. I don't like the idea of running the injectors to the ragged edge (in terms of flow volume), and the big ones don't cost much more (often times the same price) as the small ones. My tuner had no problem making them work.
Old Jun 7, 2009 | 07:05 PM
slickfx3's Avatar
slickfx3
your TPI is gone when you go SR, so cam accordingly.
auto or stick?
i have a superram, i studded the plenum box for easy nut access, the volume in the plenum will quiet bigger cam supposedly.
you can go with the 268 and still be fine mines the 290
Old Jun 7, 2009 | 07:20 PM
Kool88vette's Avatar
Kool88vette
Adjustable fuel pressure regulators are illegal in CA. I had one and failed the visual. The emissions should be fine with a good cat. You can't make any changes to the exhaust before the cats. Long tubes are illegal here.
Old Jun 7, 2009 | 07:48 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Will the factory fuel pump manage those injectors?
Old Jun 7, 2009 | 07:55 PM
slickfx3's Avatar
slickfx3
Default but you can use some ingenuity and get shorties in there!
To California Super Ram Combo
Old Jun 7, 2009 | 09:06 PM
cumbercr's Avatar
cumbercr
The AFPR I got from TPiS has an E.O. number and is CA legal. I know I'm screwed on the exhaust. I installed a Corsa catback, replaced the cat with a Magnaflow and replaced the 2-1/4" front Y with 2-1/2". So the flow is as good as its going to get. To my knowledge there are no headers that are legal.
Old Jun 7, 2009 | 09:10 PM
cumbercr's Avatar
cumbercr
auto or stick?
Mine is an 700R4 Automatic with 3.07 gears. If you're running a 290 and passing smog, I feel fine with the 268XFI. Your Super Ram plenum looks good. Is the casting quality good enough to polish out?
Old Jun 7, 2009 | 09:30 PM
Kool88vette
Edlebrock made shortys with a carb #. Summit had them but I can't find them now.
The smog tech told me that all adjustable fuel regulators were illegal in CA. I had to change it and put an OEM back on to pass. You have to pull the superam plenum off to change the fuel regulator.
That was a year ago.
