California Super Ram Combo
Old Jun 8, 2009 | 10:30 AM
  #41
Kool88vette's Avatar
Kool88vette
Originally Posted by Beach Bum
I ran your set-up for years when I lived in California. It smogged clean as a whistle, just have everything hooked up and a cat installed. They are right about the headers, none have carb #'s, you can get a few inspection shops to overlook it, its just a visual thing..... consider tipping. :o I always had an adjustable fuel regulator, but never had that questioned..... or even looked at.
Your set-up is very good for building exceptional midrange torque..... it took my 85 to mid to low 11's at close to 120 mph. Your throttle response will be extremely snappy.... You should be able to make around 450 HP @ 5700 rpm - 500 ftlbs @ 4000 rpm with that set-up, maybe even a bit more HP if you port your SR intake..... thats enough power for very deep 11's if you're able to optimize.
As a note, your 24lb injectors are fine, I ran the Ford SVO 24lb injectors.... didn't even turn up the pressure.... tried it a few times with up and around 50 psi, but it didn't go any faster so brought back down to around 42-44 psi.
good luck
I've lived here 18 years. Things have changed with the smog tests. My 88 passed a smog without any problems twice. They hardly looked at anything before. The visual was a joke at most smog stations.
Last year was different. The smog techs are getting hit with fines for overlooking things and are very paranoid.
Last year my 88 passed the emissions test and still failed the visual because of an adjustable fuel pressure regulator. They are getting very nit picky.
My L98 runs fine with a stock fuel pressure regulator, 24 lb. Trickflow injectors and a custom tune. I think the stock pressure is 44 lbs. The guy that tuned my 88 said he can size any combo and dial it in. I think 24 lb. injectors will be fine. Take the advice of the people that have already run this combo successfully.
Old Jun 8, 2009 | 11:49 AM
  #42
slickfx3's Avatar
slickfx3
Originally Posted by GREGGPENN
More.
With your completely new 383 bottom end, SR, AFR 195's, big cam, ZF6, and decent headers, I gotta think you're at least 400rwhp. Partly depends on the tune and what's behind your shorty's.
What's behind the Shorties are the 2.5 inch mandrel Magnaflow Y pipe with their cats I suppose they are Highish flow, stock but newish main cat, and CORSA! cat back.
What percent do you add to find crank HP? or the other way around?
Old Jun 8, 2009 | 01:36 PM
  #43
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
For manual cars that don't have "extra" restriction, I take 17% off crank #'s to estimate what gets to the ground.
Then, remove more for elements that aren't ideal and a bit for accessories. (Because of your exhaust, you might be another 5% off crank. Just a guess tho.)
Old Jun 8, 2009 | 01:46 PM
  #44
GREGGPENN's Avatar
GREGGPENN
Stock pressure may be a bit less (according to FIC). I've heard numbers as low as 39-40psi. So, plan accordingly. Your tuner's comment about dialing in any combo should be qualified. When I asked Jon about using larger injectors, I asked about min and max pressure. There was a (fairly high) minimum pressure -- especially on des 2/3 units. And, you want to stay reasonably high on DC as well. IOW, you can shorten pulse width but don't install something that forces it terribly short.
My preference is to do like you did and pick an injector on the smaller side to insure good pressure and DC (e.g., Ford 24lbs units -- that shoot ~25.6lbs in our rails). While something like 36-42lb injectors could be made to work, I'm skeptical about that being a good option.
Old Jun 8, 2009 | 10:28 PM
  #45
slickfx3's Avatar
slickfx3
Originally Posted by cumbercr
By the way Slick I just downloaded the E.O. for the TPiS adjustable fuel pressure regulator. It is definitely CA legal. Has been since 1991. With a 268XFI or LPE 219 cam and the AFPR, I should be able to use my 24# Bosche III's. Did you step up to the 1,000 CFM throttle body? It's legal too.
everybody know a the stock TB flows 850cfm ( thats a huge carb) and you can modulate the opening for a more refined transition, vs. a bigger hole faster,
you can mimic that with a faster foot smaller hole.
this is my understanding, but let the real guru's comment.
Old Jun 9, 2009 | 12:12 AM
  #46
cumbercr's Avatar
cumbercr
Interesting. I thought the 85 stock throttle body was 660 CFM. If it is 850, you're right. 850 is a pretty big carb. There's not a lot more to be gained by the 1000 CFM and it is costly.
Old Jun 9, 2009 | 12:37 AM
  #47
USAsOnlyWay's Avatar
USAsOnlyWay
Originally Posted by Pete K
I wish someone would have told me 24# er's would not work.
I have been running them on the same combo for 14 years.
Interesting.
I'm running LS1 25# injectors... no issues on my 383 SR.. 42# injectors would be just stupid unless you are going boosted in the NEAR future.
Old Jun 9, 2009 | 01:08 AM
  #48
GREGGPENN's Avatar
GREGGPENN
650-660cfm has been posted around here quite a bit too. But, after finding this test, 780cfm might be "the number". (Unless an '85 unit is lower than what was measured???) Seems like there's some minor differences in the TPI TB units for IAC. So, it's possible that earlier units could be lower.
Slick might be thinking of the 52mm -- thinking 850cfm.
Old Jun 9, 2009 | 02:02 AM
  #49
slickfx3's Avatar
slickfx3
No I was under the impression the 48 flowed 850, hence my not needing to spend more money
and besides I have an airfoil, I guess that test busts that myth that airfoils don't do diddly...
what would be the symtoms if the TB was too small? inability to rev?
that's not a problem with my car, plausibly the huge plenum with the SR, is a big hopper and does not run out of air molecules as soon as someting with fewer cubic inches like a smaller plenum (stock) or miniram type.
Old Jun 9, 2009 | 02:20 AM
  #50
GREGGPENN's Avatar
GREGGPENN
Air foils don't do diddly for a car that's sufficiently fed with a stock TB. But, they will improve flow. Stockers motors don't need extra TB flow. Also, as I posted in another thread, get rid of your plastic TB. It could easily ruin your motor. What do you think the results will be -- if it breaks off and gets sucked in?
Symtoms are reaching a lower power level than possible. For your motor, having a larger than stock TB will provide a bit more power. I'd guess in the 10hp range. Your SR plenum won't keep it from running out of air.
Make sure you have a descreened MAF or larger MAF housing. If you're running a stock MAF, that's a bigger problem.
Remember the weakest link in a chain will limit your power.
Old Jun 9, 2009 | 10:02 AM
  #51
bjankuski's Avatar
bjankuski
The stock 48mm throttle body flows around 660 cfm.
Old Jun 9, 2009 | 10:22 AM
  #52
Kool88vette
The tuner didn't say you can use any injector. He said he could take any combo of engine, intake, cam and heads and figure out the right size injector and then dial it in.
Old Jun 9, 2009 | 10:48 AM
  #53
GREGGPENN's Avatar
GREGGPENN
That sounds better. I thought you were telling people they could pick any ol' size of injector (like the 42lb example) and, if they got a got tuner, they could get it to work (well). IMO, your prior post could have been interpreted that way.
On behalf of people buying huge injectors, thanks for the clarification.
Old Jun 9, 2009 | 10:53 AM
  #54
GREGGPENN's Avatar
GREGGPENN
Well, Brian, that's what I'd always heard before I found the "university" study linked (in post #48) above. Are you certain you're right and they're wrong (about their 780cfm measurement)? For example, is there at least one TPI/LTx TB that flows more? (That they might have measured.)
IOW, can you provide an guess/explanation regarding any error you see in their results?
Gregg
Old Jun 9, 2009 | 11:04 AM
  #55
slickfx3's Avatar
slickfx3
I forgot I had the TB ported,I don't know if that is effective, the foil is not really plastic, felt like nylon...
stock MAF and papaer air filter with aftermarket cutout lid....
