Knock Sensor Boot
Old Jun 7, 2009 | 06:18 AM
Frank-in-San-Diego's Avatar
Frank-in-San-Diego
Default Knock Sensor Boot
1987 Corvette
Hey, where can I buy a knock sensor BOOT. That rubber connector of the left side - low, for the sensor in the block. It is round, I remember it as having a black rubber boot. The boot is gone, the connector is plugged it but it is just a lead on a wire. I have purchased out of catalogs - all oval hard plastic (wrong).
Got any ideas??
Old Jun 7, 2009 | 08:06 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Here is a pic of my spare connector, it is correct for knock sensor and aux fan temp switch.
Did the oval one, look like this ??
Old Jun 7, 2009 | 08:44 AM
Frank-in-San-Diego
No - Mine is round rather than oval. Mybe this is the problem - wrong sender?
Old Jun 7, 2009 | 03:41 PM
RLG's Avatar
RLG
I have been looking for this part, I would appreciate the info as to where I can get one. I have looked at a few catalogs ,but haven't found it yet.
Mine was brittle with age and just fell apart.
Old Jun 7, 2009 | 03:59 PM
jeffp1167's Avatar
jeffp1167
even though that connector is oval shaped that is the correct one for both the fan sensor and knock sensor. Yes it oval while the sensor is round but its like that so when you push it on it locks and seals and wont come loose.
Old Jun 7, 2009 | 04:16 PM
SunCr's Avatar
SunCr
Poop Boys has/had this weatherpak; NAPA can usually look it up and order it if not in stock. If you swap it out, you need a good connection (like any Sensor circuit) so make sure that the splice is a good one OR crunch the old connector with some pliers, reform the locking tang, and reinsert the existing wire.
Old Jun 7, 2009 | 05:43 PM
RLG's Avatar
RLG
thanks SunCr,
I prefer using the original wire.
Old Jun 8, 2009 | 07:04 AM
floridamale's Avatar
floridamale
http://www.eficonnection.com/eficonn..._pigtails.aspx
To Knock Sensor Boot
