1988 Spark plug question
Old Jun 7, 2009 | 06:30 PM
planet's Avatar
planet
Default 1988 Spark plug question
What is the best spark plug for a stock engine? Darn fat fingers.
Old Jun 7, 2009 | 06:40 PM
Pete K's Avatar
Pete K
It doesn't matter. Buy the correct size, and heat range, and the engine won't know the difference.
I normally run AC, because they are often on sale.
Old Jun 8, 2009 | 12:11 AM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
likely you'll get many opinions.
ACDelco was likely the OEM plug (41-808 platinum - gap 0.035).
However, some ACDelco 'platinum' plugs (e.g. 41-906) where known (I had 3) to loose their platinum 'puck' (dab of platinum on underside of ground electrode), which at best just left the gap way too large.
Unfortunately, ACDelco doesn't make an 'iridium' plug for your engine, which would be the best choice.
And assuming you have an aluminum heads engine, NGK also doesn't make an 'iridium' plug for your engine either.
So assuming you have aluminum heads (see below for clarity if your not sure), I would select the ACDelco platinum and reduce the 'lost puck' chances by replacing them every 25-30k.
Interestingly, NGK's site notes the 1988 engine as having both aluminum and cast-iron head options.
Appears the distinction is the aluminum heads took a flat/gasket seat type plug -- whereas-- the cast-iron heads took a tapered seat (backwards of what I would have expected -- unless of course it's incorrect).
It further calls for either a 5155 (FR4) (NGK v-power for aluminum -- flat/gasket seat) or 6630 (UR4) (NGK v-power for cast-iron tapered seat) or 7401 (UR4ix) (NGK Iridium for cast-iron tapered seat).
The FR4 is 14mm hex, 5/8" thread diameter with a 3/4" (19mm) reach.
The UR4 (& UR4ix) are a 14 mm thread diamater with a .460" reach.
Old Jun 8, 2009 | 11:43 AM
josephf31's Avatar
josephf31
Default It
will matter if you use a cheap POS like Autolite, stick with AC Delco, Champion, Bosch, etc.
Old Jun 8, 2009 | 12:17 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
For my LT1, I like the NGK TR-55 Double Platinum.
Old Jun 8, 2009 | 06:12 PM
Pete K's Avatar
Pete K
Ya think.
I ran autolites in my work truck for 440,000 miles, changing them every 100k.
Different results for different folks I guess.
I can't keep a champion in my chainsaw for more than 1 month, but I bet some will say they are the best thing since sliced bread.
Spark plug opinions are just that. Opinion.
Old Jun 8, 2009 | 07:25 PM
samsonb's Avatar
samsonb
I put AC Delcos in my 89. Though they rusted up on the outside where you attach your wrench. I don't know why they did that.
Old Jun 8, 2009 | 09:40 PM
Kool88vette's Avatar
Kool88vette
I put a set of Bosch Plus 4 Platinums in my 88 about 5 years ago and they are still good. They are supposed to last 100,000 miles. http://www.boschautoparts.com/Produc...lugs/Platinum4
Old Jun 9, 2009 | 10:36 AM
onedef92's Avatar
onedef92
Ya think.
When I bought my '92 back in 2000, the previous owner was running AutoLite Platinum plugs and the car had 63,000 miles on it, a new Opti and a new water pump. I kept the plugs on there until I reached 93,000 miles and they never missed a beat.
Old Jun 9, 2009 | 10:48 AM
josephf31's Avatar
josephf31
Default Yeah
the Platinums are good, and the el cheapo ones are OK for a weekend driver or a non performance vehicle.
Old Jun 9, 2009 | 10:53 AM
onedef92's Avatar
onedef92
Thanks for the clarification. I run NGK copper cores in my DD Toyota Camry, but I usually don't run them than any longer than 15,000 miles before swapping them out.
Old Jun 9, 2009 | 06:37 PM
Pete K's Avatar
Pete K
I guess it is good we cleared that up.
Old Jun 10, 2009 | 09:44 AM
onedef92's Avatar
onedef92
Why, yes. Yes, it is.
To 1988 Spark plug question
