94 ABS new sound
Old Jun 8, 2009 | 04:03 AM
llesg's Avatar
llesg
Default 94 ABS new sound
My ABS has started to make a different sound than usual when I am backing out the driveway.??? Clues
Old Jun 8, 2009 | 12:07 PM
pcolt94's Avatar
pcolt94
Please add more information and better description of events.
I’m not even guessing on this.
Old Jun 9, 2009 | 03:14 AM
llesg's Avatar
llesg
OK,When I back the car out the ABS always makes a sound,It comes from behind the drivers seat.Its like a" reset" sound,can't really describe it. Anyway the sound has changed
Old Jun 9, 2009 | 07:06 AM
pcolt94's Avatar
pcolt94
Check to see if the ABS is still working. Make a hard stop on dirt or gravel to see if you can get the wheels to lock up and see if the clicking noise is still heard and the brake pedal pulsates. Try to find out what’s not working or what problem there is.
Old Jun 9, 2009 | 07:12 AM
Casethecorvetteman's Avatar
Casethecorvetteman
What you should probably look at is the sound deadening under the cover, it may have moved.
Also, when you bleed the brakes, you must bleed the whole system in order, starting with the bleeder on the ABR/ASR unit, which will bleed the 3rd line that is connected to the reservior.
To 94 ABS new sound
