Dyno Numbers!
Old Jun 8, 2009 | 09:15 AM
techvette's Avatar
techvette
Default Dyno Numbers!
Over the weekend, I strapped my stock LT4 to the dyno:
297 rwhp
302 rwtq
Not a bad place to start...I'm thinking a full Borla exhaust, long tube headers, LT4 hot cam, and a dyno tune should really wake it up!
All it takes is money, and that might take a few months...Still, I'm happy with those numbers!
Old Jun 8, 2009 | 02:05 PM
johnnymo63's Avatar
johnnymo63
2021 C4 of the Year - Modified Finalist
C4 of Year Finalist (appearance mods) 2019
I dynoed my all-stock LT1 a couple of years ago w/ 270 hp & 301 tq ATW.
LT4s are rated 30hp higher than LT1s, so you are right on target.
Those mods you want should really wake it up. Good numbers.
Old Jun 8, 2009 | 02:43 PM
LT4POWR's Avatar
LT4POWR
sounds about right....definitely a healthly starting point
Old Jun 8, 2009 | 06:42 PM
96 lt-4's Avatar
96 lt-4
Skip the headers and have the heads ported.An electric water pump is a proven gain as well.
Old Jun 8, 2009 | 06:59 PM
farscape1a's Avatar
farscape1a
doing the heads is good if you want to completely tear down the engine. if you just want to do bolt-on's, headers and full exhaust is the way to go. but at the same time, the cam isn't exactly bolt on...
Old Jun 8, 2009 | 07:12 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
Very good starting numbers
Old Jun 8, 2009 | 09:06 PM
856SPEED's Avatar
856SPEED
that's stock ls1 territory...some stock ls1's dyno less than that...(auto equipped mainly)
Old Jun 9, 2009 | 09:25 AM
techvette's Avatar
techvette
lt4 > ls1
Old Jun 9, 2009 | 02:03 PM
tpivette's Avatar
tpivette
more proof that the LT4s are stronger than advertised, and every bit as powerful as the LS1s that replaced them
my bone stock LT1 dynoed 266/306, so it looks like LT4s were 30hp stronger than a LT1... except that figure seems to be REAR WHEEL hp, not flywheel
awesome #s!
Old Jun 9, 2009 | 03:38 PM
Mojave's Avatar
Mojave
LT4 dyno results and the LT4>LS1 discussion starts up...again.
I'll take an LS1 over an LT4 every day of the week, and twice on Sunday (and yes, I actually own one of both).
To the OP: Nice numbers! Long tubes and exhaust is a great starting point. I'm not a big fan of the EWP, but others really like them. Head and intake porting with a cam will add some power, but that's hardly bolt on work.
Old Jun 9, 2009 | 04:49 PM
techvette's Avatar
techvette
Originally Posted by mojave
lt4 dyno results and the lt4>ls1 discussion starts up...again.
I'll take an ls1 over an lt4 every day of the week, and twice on sunday (and yes, i actually own one of both).
To the op: Nice numbers! Long tubes and exhaust is a great starting point. I'm not a big fan of the ewp, but others really like them. Head and intake porting with a cam will add some power, but that's hardly bolt on work.
ewp???
Old Jun 9, 2009 | 05:10 PM
steven mack's Avatar
steven mack
Electric water pump /EWP
Old Jun 9, 2009 | 09:22 PM
jonecap's Avatar
jonecap
For what it's worth, my LT4 made almost the exact same numbers as yours stock.
- with headers, tune, and electric water pump it made 327rwhp and about the same torque number
- with a Hotcam it made 354rwhp & 348rwtq
- with no belt on it, it made 361rwhp
Old Jun 9, 2009 | 10:05 PM
Mr. Peabody's Avatar
Mr. Peabody
You aren't going to gain much if anything from an aftermarket cat back system. Your LT4 stock exhaust is fairly non restrictive up to about the volume need for 400rwhp.
LT headers and the hot cam will do much more for you than an exhaust system.
Old Jun 9, 2009 | 10:08 PM
cv67's Avatar
cv67
St. Jude Donor '05
Avg LT1 260ish rwhp rated at 300hp
Avg LT4 290ish rwhp rated at 330hp
Difference of 40 hp+- each. What am I missing, how are they stronger than advertised?
Old Jun 9, 2009 | 10:28 PM
STL94LT1's Avatar
STL94LT1
Old Jun 9, 2009 | 10:33 PM
bobmic93's Avatar
bobmic93
port the heads, slap in a new cam some LTs and tune and you will be very close to 400 rwhp and will be able to run with any corvette out there except maybe the new Z.
To Dyno Numbers!
Old Jun 10, 2009 | 07:36 AM
rickneworleansla's Avatar
rickneworleansla
Avg LT1 270ish rwhp rated at 300hp
Avg LT4 300ish rwhp rated at 330hp
Difference of 30 hp+- each.
Old Jun 10, 2009 | 07:42 AM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
All the LT4s are stronger than what GM told us.
Lots of theories. Do a search here. I do not want to add to the speculation.
All I will say is this: I own an LT4 that I purchased new. I have over 106,000 miles. I have spanked every stock C5 I have ever seen. You tell me why!
Old Jun 10, 2009 | 07:53 AM
rickneworleansla
Back in 04/05 when my LT1 was still stock I also beat several C5's. I guess my LT1 is under rated too.
