Should have checked here first
Old Jun 10, 2009 | 09:13 AM
93v's Avatar
93v
Default Should have checked here first
Changed the oil in my 93 lt1 yesterday,put in full synthetic, have oil leaks in numerous spots now.I guess it didn't have synthetic in it before?I guess I'll have to drain it out and put in syn. blend.I'm pretty sure that's what was in it before and only had some minor leaks.I just hate to throw away 35.00 worth of good oil.
Old Jun 10, 2009 | 09:25 AM
engle1147's Avatar
engle1147
Most synthetics are super thin and will allow leaks to become more visable on a older/higher mileage application.
Old Jun 10, 2009 | 09:38 AM
pmihaltian's Avatar
pmihaltian
Slingshot
Fix the leaks and keep the Royal Purple
Old Jun 10, 2009 | 09:42 AM
floridamale's Avatar
floridamale
Since 1992, Mobil 1 has been the factory and service fill lubricant for all Corvettes manufactured by General Motors.
Old Jun 10, 2009 | 10:06 AM
93v's Avatar
93v
Haven't been able to see where everything is leaking yet,looks like the rear of the engine and around the oil filter mounting area.Are these common leak point's?Thanx
Old Jun 10, 2009 | 10:17 AM
94z07fx3's Avatar
94z07fx3
I suggest you buy a dye/light/glasses kit and see the leaks.
Fel-Pro intake, valve cover, and oil pan gaskets will give you a nice ventage car that is leak free. (Right stuff of course!)
Your leak could be as simple as pulling the sending units and wraping their threads with teflon tape. Won't know until you see it tho...
Old Jun 10, 2009 | 10:22 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
could also be as simple as tightening your pan gasket as well. Remember not to overtorque the bolts. pan bolts..small, 50 inch lbs, large, 8 ft. lbs
Old Jun 10, 2009 | 10:37 AM
93v's Avatar
93v
Will check the thing's youy guy's mentioned and post result's in the next few day's.thanx for the help guy's
Old Jun 10, 2009 | 12:17 PM
MK 82's Avatar
MK 82
Originally Posted by 93v
Will check the things you guys mentioned and post results in the next few days. thanx for the help guys
Fixed it.
Old Jun 13, 2009 | 08:41 AM
93v's Avatar
93v
Tightened down all the loose stuff(pan bolts,intake,oil filter adapter)got most of the oil leaks in check.Still leaks a little bit but not bad for a 218,000 mile carthanx guy's
Old Jun 13, 2009 | 08:09 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
Even though synthetic oil is thinner, most of the reason NOT to use it in older cars which didn't use synthetic before, is its cleaning properties, not its thinness.
Over time (not 1 day), the synthetic cleaning agents tend to remove deposits left by dino oil and create some oil leaks that didn't exist before.
So, one last concern/thought -- did the old oil filter gasket come off with the old filter (check the garbage to be sure).
Old Jun 13, 2009 | 08:25 PM
pologreen1's Avatar
pologreen1
mobil 1 in all mine, and never a problem related to oil yet.
Old Jun 14, 2009 | 08:07 AM
HlhnEast's Avatar
HlhnEast
On toipic but non Vette, I just bought a new GMC 4X4 and its time for the second oil change, 6K in 45 days, sheesh......... Anyway, is it time to put syntho in now? I have heard that it isnt good for break in but you want to swap over as soon as possible.
What about PTFE products? I Slick 50'd my last GMC around 40K, again at 100 and it was still strong after 200+
My '85 Coupe is long past the syntho stage but with a rebuild on the horizon, I will be looking into the same issue soon with it.
TIA!!
Old Jun 14, 2009 | 09:38 AM
c4cruiser's Avatar
c4cruiser
TIA!!
I have an '08 Silverado with the 6.0L motor and I changed oil at 1300 miles (dino) just to get any gunk out of the motor. At 3200 miles, the next oil change was to Quaker State synthetic blend (a dealer freebie).
I'll be going to a full synthetic (Mobil-1 5W-30) at the next oil change and use 5000 intervals between changes. Today's new engines don't really need additives. They are cleaner, the machining is more precise and the materials are better.
OEM recommendations for oil change intervals are going up even with the use of regular dino oils. And with oil life monitors as part of the DIC displays, it's easy to track oil life.
I tow a 5600 lb trailer with my truck so I think a full synthetic will work fine for me. As long as Wal-Mart keeps having sales on Mobil-1, it's easy to justify the additional cost of a synthetic oil.
To Should have checked here first
