Soap residue!
Old Jun 10, 2009 | 04:06 PM
MP6's Avatar
MP6
Default Soap residue!
i washed my car today and between mixing too much concentrate and the heat of the car i have a film on the car im having a hard time with getting off! what should i do whats the best way to get it off!?
Old Jun 10, 2009 | 04:13 PM
engle1147's Avatar
engle1147
Probably shouldn't park it in the sun until you get it off. Maybe try some WD40 in a small spot and rub it with a soft rag and see if that helps.
Old Jun 10, 2009 | 04:30 PM
dreamer2468's Avatar
dreamer2468
St. Jude Donor '09-'10-'11
Maybe just rewash with just water, cleaning with a microfiber towel to help remove the residue.
That may delute the concentrate enough to remove it.
Hope it works.
Laura
Old Jun 10, 2009 | 04:42 PM
floridamale's Avatar
floridamale
Rinse off with water to remove soap build up go get some detailing spray
Old Jun 10, 2009 | 04:45 PM
mwar410's Avatar
mwar410
Cruising
+1 on the detailing spray, I can't wash my car without finishing it with mother's detailing spray. Black custom paint, shows every water spot.
Old Jun 10, 2009 | 05:37 PM
LT1CORVETTE's Avatar
LT1CORVETTE
When it is not sunny rewash the car.
If that doesn't work try mixing some white vinegar (buy it at the grocery store by the gallon) in a spray bottle and spray the car down and use a was mit on it was car wash solution. Then rewash.
If that doesn't work try some Meguairs scratch x or a mild paint cleaner and a foam applicator or microfiber towel. If that works do that over the entire car then wax.
Old Jun 10, 2009 | 07:58 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
and find some shade to do it in.
Old Jun 10, 2009 | 08:10 PM
pologreen1's Avatar
pologreen1
rinse again in the shade, and use a good cloth
Old Jun 10, 2009 | 08:38 PM
MP6's Avatar
MP6
yeah i power washed at a wash place today. got must of it off. im gonnna get it buffed out too. thanks for the help!
To Soap residue!
