New Problem
Old Jun 10, 2009 | 04:20 PM
Chapindad's Avatar
Chapindad
Default New Problem
My 87 won't start. I am getting 42 pounds of pressure on the rails. I am going out in a few to check the spark.
Old Jun 10, 2009 | 04:46 PM
floridamale's Avatar
floridamale
Is the car cranking and not starting or not even cranking over
Old Jun 11, 2009 | 11:29 AM
Chapindad's Avatar
Chapindad
Sorry. It turns over strong but it won't crank. I plan to go and purchase a timing light tonight and test the spark. I love this car but my wife is going to kill me if I have to spend a bunch a money to get it working. I just replaced the transmission in it a month ago.
Old Jun 11, 2009 | 12:21 PM
floridamale
Ok so it's turning over after checking the spark if it's Ok you need to test the resistance on the injectors with a ohm meter also you need to test if they are pulsing or getting a signal. Do you have a FSM they can be a big help in trouble shooting but if you report your trouble people here should be able to get you on the right tract
Old Jun 12, 2009 | 08:27 AM
Chapindad's Avatar
Chapindad
Here is more of the story that I should have posted first. The car was driving great. I was coming home and had just pulled on to my street when the motor stalled out. I had no warning of anything bad and it was driving great.
Old Jun 12, 2009 | 08:50 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I had a similar situation, I pinched the tach wire under the cap, after a few days of driving, the wire shorted to ground.
Have you had the cap off lately ??
Have you checked all fuses ??
Pull a spark plug wire and place the end the exhaust manifold, you should be able to see the spark jump, or hang onto the end and have the wife turn the ignition to crank.
Old Jun 12, 2009 | 10:21 AM
383vett's Avatar
383vett
That's cruel.
Old Jun 12, 2009 | 12:28 PM
Epimax's Avatar
Epimax
Might be the ICM and/or Coil...
Old Jun 12, 2009 | 12:34 PM
Epimax's Avatar
Epimax
Or, if you want a permanent ticket to the dog house, you could have the wife hang on to it and you turn the ignition to crank...
Old Jun 12, 2009 | 01:07 PM
Randy93's Avatar
Randy93
St. Jude Donor '06
A fuel pump that is going out can give perfect pressure and still be bad, ask me how I know.
My pump would run for a second or 2 when I turned the key and then die. Looked at the fuel pressure when I turned the key to 'ON' and pressure was fine, didn't notice till I tried to turn it over while I watched the motor(don't know what I thought I might see) and just happened to glance at my fuel guage and it was reading about 10lbs. Turned the key off and then on and fuel pressure went right back up and would drop as I tried to start the car. Called a friend who owns a repair shop and he told me fuel pumps can run overheat and shut down or pump so slow it can't keep up w/car needs.
Sorry to be so long winded, this started as a one liner.
Old Jun 12, 2009 | 01:46 PM
Black84's Avatar
Black84
If I were a betting man I would bet on the coil having gone bad...
Old Jun 21, 2009 | 02:57 PM
Chapindad's Avatar
Chapindad
I have been on vacation in the keys for my sister's wedding. it was great, but now I am back to reality.
I just tested for spark and I have zero. I will go pull the distributor cap in a few.
Old Jun 21, 2009 | 07:05 PM
Chapindad's Avatar
Chapindad
I just replace the button, Cap and coil. Still will not start. Need to check the spark again but I was being eaten alive by the darn bugs.
Old Jun 22, 2009 | 06:25 AM
Chapindad's Avatar
Chapindad
Still no spark. What is left?
Old Jun 22, 2009 | 06:42 AM
86PACER's Avatar
86PACER
Fuses, pick up coil, and ignition module.
Test your pick up coil (not to be confused with the ignition coil that you just replaced). It's inside the distributor.
Autozone can test your ignition module for free. (under the dist cap as well).
My pick up coil went out and the engine died on me on the freeway, never to restart.
Old Jun 22, 2009 | 08:05 AM
AGENT 86's Avatar
AGENT 86
Do you have battery power at dizzy ??
http://members.shaw.ca/corvette86/Ig...System-EST.pdf
Old Jun 22, 2009 | 09:20 AM
Qiken's Avatar
Qiken
To New Problem
Old Jun 22, 2009 | 03:23 PM
Chapindad's Avatar
Chapindad
Okay. I have printed off all the information. Looking at the documentation, it looks like a son of a B@tch to replace the pickup coil. Am I going to have to remove the Distributor completely to replace the Module and/or pickup coil? If so then what is the best way to keep from causing myself a huge problem. I did this once on a 72 Firebird and it took me a day to get the teeth lined back up.
Old Jun 22, 2009 | 03:37 PM
86PACER's Avatar
86PACER
After removing the cap, draw a mark on the distributor metal housing in the direction where the rotor tip is pointing.
If you do this, you will hold the timing. All that's left is to get the dist to fully seat.
Old Jun 23, 2009 | 06:45 AM
Chapindad's Avatar
Chapindad
I tested the pickup coil leads and I am getting zero ohms out of it, so I am guessing this is my problem. I should have a new one today and I will try and replace it over the next few days.
