Best Wires for Headers?
Old Jun 11, 2009 | 12:10 AM
89Corvette6spdFX3's Avatar
89Corvette6spdFX3
Default Best Wires for Headers?
Does anyone have suggestions for plug wires to stand up to LT headers? I currently have Taylor Spiro Pros but they are around 5 years old. I don't think they will handle the heat of the headers.
What have you used?
Old Jun 11, 2009 | 08:36 AM
jimmers's Avatar
jimmers
I have a set of Hooker headers and use MSD wires.
Old Jun 11, 2009 | 12:44 PM
ultraviolet70's Avatar
ultraviolet70
You can always put protective boots on the wires, it helps immensely.
The black flex loom is mostly for looks, but also helps with cross arcing.
Old Jun 11, 2009 | 01:16 PM
STL94LT1's Avatar
STL94LT1
I've been running my Taylor Spiro Pro's for ~8 years with headers, and no problems.
Old Jun 11, 2009 | 01:21 PM
jerkyboy's Avatar
jerkyboy
Is that flex loom plastic? I like the looks
Old Jun 11, 2009 | 01:28 PM
vader86's Avatar
vader86
The wires will hold up for the 2 years you should leave them in until you are supposed to change plugs/wires again, but depending on the header brand and fitment to the heads, you might notice wires with thicker boots will touch the header pipe, those cloth boots are the only way you will get around not having to replace wires once a week.
They'll burn through very fast.
Mine rub the wire boot on #7 and #6, so even with the boot protectors on, I end up changing out a wire every couple months.
Old Jun 11, 2009 | 01:29 PM
ultraviolet70
Yes just plastic 3/8 loom. The 3/8 will fit over up to 9mm wires and you can get 50ft rolls from Summit for around $10-$12, cheapest I found it and I just buy large rolls of it because I use it for everything (took like 20 plus feet to do the plug wires).
Old Jun 11, 2009 | 02:09 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
How about a set that mounts by being routed under the headers?
That's what I picked.
Old Jun 11, 2009 | 02:45 PM
eguyett1985's Avatar
eguyett1985
That's what I did too. It's more work but I used the MSD 8.5's in the extra long universal kit with 90 degree boots covered with the MSD Pro Heat Guard for abrasion and heat resistance and ran them under the headers...ala C3 style. I have no heat or clearance issues at all plus I think it looks cleaner.
Old Jun 11, 2009 | 03:09 PM
GREGGPENN's Avatar
GREGGPENN
What's "MSD Pro heat guard"? Is it boots, spray, or other?
8.5mm is what I was looking at until I found this set of 10mm race-grade wires...
SBC CHEVY RACE GRADE SPARK PLUG WIRES 10MM BLK 327-OMK
I found them on everybody's favorite auction site.
Old Jun 11, 2009 | 03:17 PM
eguyett1985
http://www.msdignition.com/Products/...eeve,_25_.aspx
It's a sleeving material but it's not going to work on a 10mm wire I'm certain, it is a tight fit on the 8.5's. One roll of 25ft was enough for me to do all 8 wires and then I used shrink tubing at each end to seal it to the wires.
Old Jun 12, 2009 | 08:40 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Have you run the motor yet ?? If not, I see a melt down coming your way. I had a piece of that stuff, over the aux fan temp switch wire. It didn't last long.
To the original poster, I think it's more about wire routing, than what wire. I'm using the stock looms and wires and not a hint of burning around headers.
Old Jun 12, 2009 | 01:56 PM
89Corvette6spdFX3
I sure like the look and idea of routing them under the headers and up the back of the engine. That really looks good! I think I'll hang on to mine for awhile and see what happens, then maybe custom make a set to like those above. I'm dying to get my car running well and be able to drive it!
Old Jun 12, 2009 | 03:04 PM
GREGGPENN's Avatar
GREGGPENN
That was my thinking when I picked the under the header config. Do you use this routing or something else?
Old Jun 12, 2009 | 03:12 PM
AGENT 86's Avatar
AGENT 86
I'm using the stock routing.
Old Jun 12, 2009 | 03:16 PM
techvette's Avatar
techvette
Dang, I am still running the plugs and wires installed at the factory!
Old Jun 12, 2009 | 03:24 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
I'm using the MSD wires and Made4You wire looms
Seems to be working great.
http://www.summitracing.com/search/B.../?autoview=sku
To Best Wires for Headers?
Old Jun 12, 2009 | 03:32 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
I've had zero problems with my Taylors, on any of my header equipped cars.....
Old Jun 12, 2009 | 08:04 PM
reoch999's Avatar
reoch999
I'm using taylor 8.2mm. I haven't had any trouble yet, but when I start the engine for the first time this weekend, I may have a different story. I specifically asked for all 90* boots when I ordered from summit, but got a set with two straight boots. One of the straight boots is fine on the #8 plug, it isn't even close to the header. But the other one had to go on #3 and it's only a couple millimeters away from the header. I plan on zip tying it to the #1 wire to keep it as far away as possible, but it's close enough I'm liking the idea of that high temp wrap pictured above by ultraviolet.
Old Jun 12, 2009 | 08:40 PM
STL94LT1's Avatar
STL94LT1
reoch999, what headers are you running? I used the two straight boots on #6 and #8 with both Hooker shorties and EM long tubes.
