1989 Dim Instrument Lights ???
89 C4 was a daily driver and has some miles but wanted something easy on the pocket and with some room to tweak and upgrade)Anyhow, first problem is with the Dash Instument Lights:
#1 Main info center (mph/temp/oil/tach etc) is very dim and the dimmer switch does not change this. When I rotate the dimmer switch the radio dims and brightens as it should.
#2 When headlights are OFF and Ignition is ON or running the turn signal indicators glow as well as the high beam indicator. As soon as I turn on the headlights or parking lights these all go off and function normally
I'm going to allow you to scroll down on your own and see if you can locate it.
OK oK...I feel badly
http://forums.corvetteforum.com/c4-t...sh-lights.html
http://www.advancedelectronics.org/
http://cgi.ebay.com/ebaymotors/1984-...1%7C240%3A1318
http://www.corvettedashclusterservice.com/index.html
on the broken connections; and would add that if you can use a soldering iron there is a great how-to DIY on repairing your own cluster. I have suggested it be put up on sticky; I will look around and see if I can find the link.found the link, (Mr. Moderator, how about putting this up on a sticky, it's the greatest DIY on instrument clusters that I've seen?)
http://www.batee.com/corvette/dcrg/repair.htm
