Headlight Issue
Old Jun 11, 2009 | 01:29 PM
kab3's Avatar
kab3
Default Headlight Issue
LH headlight is intermittantly staying up with the lights off. A couple of cycles of the switch & it goes down. The enclosure is very loose when up (with the RH retracted), then tightens up with both up.
Does this sound like the bushing thing?
'90 Coupe, 54,000 miles.
Thanks.
Old Jun 11, 2009 | 01:34 PM
aminnich's Avatar
aminnich
If you hear the motor running and it is not moving then yes, bushings are very likely.
Old Jun 11, 2009 | 01:36 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
I agree. Sounds like your Delrin bushings have gone ****-up to me.
Old Jun 11, 2009 | 01:38 PM
MikeC4's Avatar
MikeC4
The symptoms of bad bushings is usually a run on of the motor after the light assembly has reached it's full "open" or "close" position. Your symptom sounds more like a stripped or flat spot on the nylon gear.
Old Jun 11, 2009 | 01:41 PM
onedef92's Avatar
onedef92
Might as well replace both the main gear AND the bushings, then after you get it all cracked open. It's a fairly labor-intensive job, one you DON'T relish doing in another 10 years.
Old Jun 11, 2009 | 03:02 PM
kab3's Avatar
kab3
Of course I went to the garage, 4 tries & can't get it to stay up
I'll order the parts & the beer then wait for a SLOW Saturday.
Thanks for the replies.
Old Jun 11, 2009 | 03:40 PM
aminnich's Avatar
aminnich
[QUOTE=kab3;1570415034]Of course I went to the garage, 4 tries & can't get it to stay up
QUOTE]
Sounds like a personal problem.
Old Jun 11, 2009 | 03:53 PM
kab3's Avatar
kab3
I wish it was..........Viagra sounds easier than replacing those bushings.
Old Jun 11, 2009 | 03:56 PM
MikeC4's Avatar
MikeC4
[QUOTE=aminnich;1570415517]
QUOTE]
To Headlight Issue
