Help. Need to remove Knob for Headlight
Old Jun 12, 2009 | 05:11 PM
corvetteman3's Avatar
corvetteman3
Default Help. Need to remove **** for Headlight
I need to remove the **** to pull the digital dash on an 89. How do I remove the ****. I don't see a set screw are a spring button on the ****. Help.
Thanks guys
Old Jun 12, 2009 | 05:34 PM
JonnyAngle's Avatar
JonnyAngle
Assuming it looks like my '86, just pull like an SOB and it'll pop off. You'll bend the bracket, but it's pretty easy to bend back, and you'll see how it works then.
Old Jun 12, 2009 | 06:18 PM
c4cruiser's Avatar
c4cruiser
Remove the hush panel and from the footwell look up at the headlight switch. There should be a button that you push that allows the **** and stem to be removed from the headlamp switch. IIRC, it's either at the back or bottom of the switch assembly. There is also a nut that must be removed (holds the switch to the dash panel assembly).
The **** itself is pressed on the stem and really can't be removed without damaging it.
Old Jun 12, 2009 | 06:26 PM
SunCr's Avatar
SunCr
There's a slot in the **** where you can stick a Jeweler's screwdriver to depress the spring that holds it on. There's no reason to damage anything.
Old Jun 12, 2009 | 07:26 PM
c4sailor's Avatar
c4sailor
Old Jun 13, 2009 | 08:09 AM
PAINTER MAN's Avatar
PAINTER MAN
I have removed mine many times like this.
To Help. Need to remove Knob for Headlight
