1994 C4 Continued no Start problem
Old Jun 13, 2009 | 11:51 AM
donkeydawn11's Avatar
donkeydawn11
Default 1994 C4 Continued no Start problem
Hi all
Well had to step away from the car I will bring you up to date now
Thanks Mike c ChrisWhewell and theadmiral94 I corrected the wiring on the pug for the temp sensor going to the water pump.
I check for voltage at the A and D pins on the plug to the ICM I read very low voltage I took it to advanced auto but they couldnt test it i brought a new one and installed it car still wouldnt start. They let me return it. I also purchased a new coil but that didnt work as well.
Should I now start thinking about replacing the Optispark unit? I know the best is MSD but dont have that kind of money right now because I just put 3k into the before this happened.
Distributor Advanced about $200.00 witn out rotor Ebay $150.00 to $200.00 with rotor any other suggestions
