410's
Old Jun 15, 2009 | 12:07 PM
redvette6spd's Avatar
redvette6spd
Default 410's
These gears should have been installed in all 6spd cars at the factory.
I have roughly 405 410 hp at the crank on a LT4 what a great performance enhancement.
I was starting to get the itch for some more HP but my motor runs perfect and strong for what it is. I couldn't justify tearing it apart. If any one is in the same boat as me I recommend doing it.
Old Jun 15, 2009 | 03:54 PM
STL94LT1's Avatar
STL94LT1
Love my 4.10's
Old Jun 15, 2009 | 04:03 PM
farscape1a's Avatar
farscape1a
aren't 4.10's a little steep for every day driving? i thought 3.73's would be a little better. or is this a 2nd car for you? just curious... thanks!
Old Jun 15, 2009 | 04:10 PM
STL94LT1's Avatar
STL94LT1
At 70 mph in sixth gear I'm only turning ~1800 rpms. Nothing wrong with 4.10's for a DD!!
Old Jun 15, 2009 | 04:12 PM
383vett's Avatar
383vett
4.10's are great for the 6 speed with overdrive in 5th and 6th.
Old Jun 15, 2009 | 04:16 PM
farscape1a's Avatar
farscape1a
how about for an automatic?
i was looking to make a straight line car, and i can't shift that well. i can shift well enough to get by, but not at a drag strip...
Old Jun 15, 2009 | 05:32 PM
STL94LT1's Avatar
STL94LT1
I personally wouldn't run 4.10's in a street driven A4 LT1. I would go 3.73 if it was a weekend car, or 3.54 if it was a DD.
Old Jun 15, 2009 | 05:33 PM
farscape1a's Avatar
farscape1a
cool! thanks for the info!
Old Jun 15, 2009 | 06:02 PM
mnstrlt1's Avatar
mnstrlt1
i wanted to go with 3.90's or 4.10's but i am a little reluctant due to traction. i will be pushing for "high horsepower" number eventually with my current supercharger, and I think the short final drive will render the power useless.
Old Jun 15, 2009 | 06:24 PM
Razor89's Avatar
Razor89
Congrats
You finally did it!
Now get out and drive it!
Old Jun 15, 2009 | 06:44 PM
93 ragtop's Avatar
93 ragtop
I like them in a automatic. The thing is, you want to calculate what you will be crossing the finish line at, and keep your gear slightly under that.
edit to say, if you take a 4.10 gear, multiply by .70 for overdrive, it equals 2.87 ratio. That is a lot better then alot of cars came with before overdrive transmissions came out, for a final drive ratio.
Old Jun 15, 2009 | 06:49 PM
redvette6spd
Originally Posted by Razor89
Congrats
You finally did it!
Heh Rick Yes I did they seem to be perfect for my existing set up and should be perfect for a additional 75hp should there be something like that in the feature This should keep me satisfied for a bit I hope
Old Jun 15, 2009 | 06:51 PM
383vett's Avatar
383vett
When my car was a street/strip car, I ran 3.73s and was very happy with them. Now for a full time trailered bracket car, I run 4.30s (with a 28" tire). I am running a 4l60e
Old Jun 15, 2009 | 07:45 PM
Ed's lt4's Avatar
Ed's lt4
How much do you love that rolling punch in 1st or 2nd gear
Old Jun 15, 2009 | 08:14 PM
pianoguy's Avatar
pianoguy
Who did the install for you? I was considering a gear change before I spun a bearing - now that's on the back burner.
Old Jun 15, 2009 | 09:10 PM
redvette6spd
John Boos did them and he wasn't tickled said there a pain to get rite DRM was going to do them but but wiggled out I had a hell of a time trying to find someone.
How is your motor thing coming along are you making any mods wile its apart.
Old Jun 15, 2009 | 09:14 PM
redvette6spd
Hell yeah not only was the labor and parts pricy but it's prolly going to cost me a very expensive set of tires.
To 410's
Old Jun 15, 2009 | 11:33 PM
Snakecharmer383's Avatar
Snakecharmer383
I just got a complete rearend from www.newmancarcreations.com with 3.73's Can't wait to get them in!
Old Jun 16, 2009 | 11:14 AM
pianoguy's Avatar
pianoguy
Thanks for the info! I expect to get my engine back any day now - no major mods, just a Hotcam and tuned PCM. I'm itchin'!!
Old Jun 16, 2009 | 11:26 AM
CAJUN C4's Avatar
CAJUN C4
Definatly....4:10's are the perfect all around Ratio.IMO..of Course.
Also, they help Clutch Longevity as Long as one doesn't allways abuse it.Gas mileage not noticably reduced as well.
